Blown Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 08:40 PM   #1
blown outlet
I have an outlet in my basement that was working fine until this morning. I added a power strip so I could move my computer desk downstairs and it blew when I plugged in all my computer parts. I checked the circuit breakers (all fine) and then bought and installed a new outlet. Nothing. Any suggestions would be helpful. Thanks in advance.
BigBill73 is offline   Reply With Quote
Old 05-02-2010, 09:27 PM   #2
Just call me Andrew
Rewards Points: 1,020
Are you sure the breaker didn't trip? To turn on a tripped breaker, you often have to switch it OFF then ON.
Andrew
secutanudu is offline   Reply With Quote
Old 05-02-2010, 09:32 PM   #3
Rewards Points: 1,016
Is there a GFCI outlet upsteam of this outlet - and it's tripped? Could be in a bathroom, kitchen, etc.
Old 05-03-2010, 06:50 AM   #4
I'm sure the breakers are good. I switched all of them off-on just to be sure... freaked my kids out while they were watching TV. Thanks.
Old 05-03-2010, 06:51 AM   #5
I'll check the GCFI possibility later today. Thanks.
Old 05-03-2010, 08:00 AM   #6
joed's Avatar
Rewards Points: 12,862
Please describe what you mean by "blew". Did sparks come out of it or did it just stop working? If it just stopped working then there could be a loose connection on the receptacle or anywhere between the receptalce and the panel. The problem could even be in a working device on the same circuit.
Tags
basement , electrical , outlet , power outage
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
