Blown Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 11:41 AM   #1
Blown light switch
Ok, i turned on the light switch inside the house to turn on the outside lights, immediately the outside light blew and in addition the hall way light and the living room light/ceiling fan won't work now. I check the breaker and they all say
Charrill is offline   Reply With Quote
Old 07-01-2011, 11:47 AM   #2
if a breaker tripped it needs to be turned completely to the off position and then back on for it to reset. if it isnt the breaker then might be a burned wire in one of the boxes since more then one light are on the same circuit.
Old 07-01-2011, 12:18 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Did you actually turn the breaker to off postion however you will have to push it little more further you will feel a click then turn it back on if the lights did not come on then you have a loose connection at one of the switch box or one of the junction box so therefore check at the switch box first if not then one of the receptales connection can be bad if you don't have power there.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Blown Light Switch ogrenjr Electrical 3 03-01-2010 03:42 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
