Blown Light Circuit - HELP! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 12:45 PM   #1
Dear All,
I returned home from work this evening to find the upstairs lights not working. The fuse had blown and I have replaced the fuse wire but the lights are still not working... Any suggestions??
Thank you!
KirstyShar is offline   Reply With Quote
Old 07-07-2009, 07:13 PM   #2
Are you sure the new fuse is good?
If you heard the fuse blow when you screwed it in, unplug everything in the area affected, turn off all lights and try another fuse.
If it blows again, call someone.
If it doesn't blow, start plugging in everything and turning on the light switches to see what is causing the failure.
That's all I got.
220/221 is offline   Reply With Quote
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
Blown Circuit and More nprranch Electrical 11 12-13-2008 09:34 AM
Can a GFCI protected light be installed into a normal light circuit? boongywoongy Electrical 6 05-19-2008 08:02 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
