Blown Fuses While Changing Switches & Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 09:59 PM   #1
Blown fuses while changing switches & receptacles
My house is currently wired with aluminum wiring and I am trying to update all the receptacles and switches to CO/ALR ones. So far, I have replaced the receptacles in my kitchen and they are working, but none of my switches are working. There seems to be one fuse blowing continuously when we turn the power back on. I have since removed all the switches that I replaced, kept the wires open, and turned my power back on. The fuse still continues to blow. I've tested the receptacles that I have replaced, and they are all working. I don't understand what the problem is. Could one of the working receptacles be causing the fuse to blow still ? Any help would be appreciated. Thanks.
marc_easy is offline   Reply With Quote
Old 07-04-2009, 10:49 PM   #2
Mystery of fuse blowing when switch turned on
There is a possibility that you mistakenly installed a light switch on a receptacle. Or, if the fuse blows when you put on more than one switch, it's possible that you connected a switch (somewhere in the circuit) on a HOT and NEUTRAL wire! Diagnosing electrical problems takes good old fashioned, step by step testing. There is no magical shortcut, and no assumptions will help!!!Don't drink and Drive!!!
spark plug is offline   Reply With Quote
Old 07-04-2009, 10:59 PM   #3
addendum
One other possible reason could be that in a 4-wire "Daisy-Chain connected box of a receptacle, you mixed up some wires, and placed both, the HOT and NEUTRAL wires on the same TERMINAL, albeit on different screws!!!Don't Drink and Drive!!!
Old 07-05-2009, 05:03 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
marc easy, I guess that you are finding that Electrical is not so easy
Finding the short would have been easier if you did not replace the switches & receptacles then turn the power back on to find you had a short.
....Could one of the working receptacles be causing the fuse to blow still ?
Not likely, concentrate on the boxes that contain the switches. Look first at the box closest to the Fuse panel.
Good advice from spark plug
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-05-2009, 07:17 PM   #5
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Electrical is easy, really.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 07-05-2009, 09:18 PM   #6
spot on mag. breid
breid is offline   Reply With Quote
Old 07-05-2009, 10:04 PM   #7
Journeyman Wireman
There could be a nick in the insulation in one of the switch boxs.
jbberns is offline   Reply With Quote
Old 07-05-2009, 11:12 PM   #8
Originally Posted by jbberns View Post
[There could be a nick in the insulation in one of the switch boxs].
You're 100% right. But we assume that the visual inspection was ALREADY done! And the problem persists!!!Don't Drink and Drive!!!
Old 07-05-2009, 11:19 PM   #9
Electricity is easy, Right?!
Like some POTENTIAL customer says. "I could have done thaaat!" Oh. It took you all of five minutes. And you're charging SOOO much!!!
That's why I said POTENTIAL customer. Because when I hear any of those phrases, I don't touch that person with a Ten Foot Pole!Don't Drink and Drive!!!
Old 07-05-2009, 11:24 PM   #10
Journeyman Wireman
Just thought I would mention it. I came after a guy one time that used a razor knife to score the outer jacket of 12/3. Problem was he scored it all the way to the copper. It was very hard to see at first.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 11:49 AM
light switches wired in series -- why? magnolia Electrical 2 05-11-2008 12:16 PM
Need help replacing switches in four-way circuit magnolia Electrical 3 05-09-2008 10:40 PM
