Blower Doesn't Turn On. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 04:08 PM   #1
Blower doesn't turn on.
My fan stopped blowing last evening. Heat works fine. I found one fuse which i fine. I'm hooked up to propane. What's up?
jamesclemence is offline   Reply With Quote
Old 10-11-2012, 06:55 PM   #2
biggles's Avatar
if you have a control module within the furnace then your fan is on a delay from a heat call..relay on the board mihght be bad...did you try just FAN/ON from the stat verift the capacitor is good at leastNOTE heat runs LO/MED fan speed...cooling is always HI fan speed...if there is no control module there then your fan runs thru a thermal disc that closes as the furnace heats up,and opens as it cools down....after the stat satisfies. http://bestbuyheatingandaircondition...ry_Code=fl-tdf
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Blower NOT continuously ON on Bryant 310AAV rational HVAC 5 08-15-2011 08:44 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
blower won't turn on when heat is on, but will turn on when AC is on wavelength HVAC 6 12-31-2009 04:06 PM
