Block Heater Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 10:31 PM   #1
Solutions (handyman)
Rewards Points: 362
Block heater wire
Simple question but curious. The extension cords sold for block heaters are a 16 guage, is this enough? Is there any advantage to going to a 14 or 12 guage cord? Assuming the distance is about the same ... 15 feet.
Mark Harvey is offline   Reply With Quote
Old 12-21-2010, 11:12 PM   #2
Electrician
Rewards Points: 760
You should be fine with that cord if your only plugging in one block heater. If you are plugging two block heaters in or a block heater and an interior car warmer then you should go up to 14ga.
darren is offline   Reply With Quote
Old 12-21-2010, 11:15 PM   #3
Rewards Points: 362
Thanks Darren.
Water heater blower needs re-wire kittf Plumbing 7 12-18-2010 11:44 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 02:00 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
