Blinking Lights When Walking Near Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 06:32 PM   #1
blinking lights when walking near outlet
hi everyone, i hope this is the right spot to post this question (if not feel free to move it to the appropriate section
our chandelier in the living room blinks on and off whenever we walk near the plug outlet closest to it. The chandelier is not plugged into this outlet; the wiring is fed into it through the ceiling. When this happens, a few other appliances in the general area (plugged into near but different outlets) lose their power, but come right back on (they are 'blinking' as well, I suppose.)
So I opened the outlet in question to have a look. 2 white wires, two black, one ground. (all copper wiring). One of the white wires was discolored right where it feeds into the plug outlet, almost looks like it's 'burned' or something. I wrapped all 4 wires in electrical tape for the time being and re-attached the plug outlet. So far the blinking has stopped, but I'm not totally convinced. It's always been an intermittent issue.
Could this have something to do with the ground wire... how important is it to have the ground wire not touching *anything* else when it's shoved back into the box? It seemd difficult to shove all 5 wires back in there without anything touching eachother.
Thanks for the replies guy/gals, I'm just concerned about it, having little kids running about and everything
wireguy2012 is offline   Reply With Quote
Old 12-03-2012, 06:44 PM   #2
Rewards Points: 13,712
If the wires where just back stabed into the back of the outlet, there's your problum.
They need to be wrapped around the screws on the sides instead.
Old 12-03-2012, 07:03 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
A discolored neutral wire is a sign of a loose connection.
Replace the receptacle, and strip back the neutral wire, then connect them to the screws.
jbfan is online now   Reply With Quote
Old 12-03-2012, 07:56 PM   #4
thanks for the fast responses guys.
my apologies- our wiring is actually aluminum (if that makes any difference)
the wiring is fed (rear-inserted) into an old-style receptacle using internal clips (meaning you can't just pull the wires out or simply un-screw them).
I was concerned that the brown/black-ish color at the end of the white wire meant that it was an urgent fire hazard or something.
So I will purchase a brand new receptacle and then wrap the 4 wires (2 white, 2 black) around the screws and tighten up, would that be correct... and hopefully this will eliminate the blinking and power outages further on down the wall? thanks again
Old 12-03-2012, 08:06 PM   #5
jbfan's Avatar
Rewards Points: 478
Make sure the receptacle is marked for AL wire.
You may want to check the rest of your receptacles and switchs for the same thing.
Old 12-04-2012, 06:21 AM   #6
Rewards Points: 5,974
As stated alum. and copper don't play well together. You need to check all outlets and switches on that circuit and make sure they are all marked for AL, they can't be mixed. Also I would change that outlet and when you do don't use the back-stab they are notorious for coming loose.
Old 12-04-2012, 06:31 AM   #7
DIY staff
Rewards Points: 7,174
Moved this to electrical----------
Old 12-04-2012, 06:46 AM   #8
kbsparky's Avatar
Originally Posted by wireguy2012 View Post
.... our wiring is actually aluminum (if that makes any difference)
This makes a BIG DIFFERENCE! You have uncovered a potential fire hazard! That melted wire is a big indication of just how close you are getting to burning your house down.
One remedy as you have figured out is to replace the receptacle, and -- this is important -- you MUST obtain a device rated for CO/ALR connection.
I would also recommend that you have all the other devices in your house checked -- and replaced with proper ones for aluminum connections. The same thing can occur anywhere in your house.
-KB
The Following 4 Users Say Thank You to kbsparky For This Useful Post:
jbfan (12-04-2012), oh'mike (12-04-2012), ToolSeeker (12-04-2012), tylernt (12-04-2012)
Old 12-05-2012, 11:55 AM   #9
thanks again guys, i'll be replacing the receptacle tonight. just to clarify, there's no indication any of the receptacles are the wrong type (copper vs. aluminum)... the house is aluminum wire and as such, the receptacles are all aluminum as well (or so I would think).
The aluminum wire itself isn't melted; the white insulation around it is discolored/blackened at the tip where it enters the receptacle. So far the answers have been that this is a result of a loose connection... is this still correct?
Old 12-05-2012, 12:13 PM   #10
TTW
TTW's Avatar
The receptacles have to be marked, embossed right in the plastic CU and AL.
I just checked one I have laying around and it is marked CU, it is also marked AL in a circle with a line through it, so it is not OK for AL.
TTW is offline   Reply With Quote
Old 12-05-2012, 01:01 PM   #11
Oso954's Avatar
Rewards Points: 1,110
.... there's no indication any of the receptacles are the wrong type (copper vs. aluminum)... the house is aluminum wire and as such, the receptacles are all aluminum as well (or so I would think).
That is a real bad assumption. Unless a homeowner has been educated on the subject, they think an outlet is an outlet and a switch is a switch. So, if a homeowner has replaced any of them, you have a real good chance of having a copper only device on aluminum wire.
Oso954 is online now   Reply With Quote
Old 12-05-2012, 01:22 PM   #12
the original inquiry is why is are the lights blinking when stepping around a particular receptacle.
The copper vs. aluminum topic wasn't a part of the question. No where did anyone say the receptacles are the wrong kind... I'm not sure how that all became inter-twined with this. That's a seperate issue that somehow became mixed in... I will check everything just to be sure on that, but the first (and only) question was why do the lights blink on and off when stepping/walking in the vicinity of a certain receptacle? If it's a loose connection/loose wiring in the receptacle (which seems to be the answer) then I will definitely be changing it tonight. But again, there are no plugs in the particular receptacle... just when you walk near it, the lights come on and off intermittently.
Old 12-05-2012, 02:18 PM   #13
Rewards Points: 361
The AL comments were because I'm sure many people have made lots of mistakes with AL wired homes and no one here wishes that upon you.
The outlet in question is probably daisy chained to other outlets and potentially hardwired lights. If the connection leaving or coming into this outlet is loose anything downstream will be affected by the connection.
info2x is offline   Reply With Quote
Old 12-05-2012, 02:40 PM   #14
Oso954's Avatar
http://www.bluecrest.net/support/ele...uminum_wiring/
Old 12-05-2012, 04:24 PM   #15
thanks. I'll replace the current receptacle and check all the others in the house, too.
As far as aluminum wiring goes, there's nothing I can do to change that aside from re-wiring the entire place but that isn't something we're going to get into at the moment.
I'll start with the one spot and go from there. If the flickering is gone after the receptacle replacement then I know it was a loose connection. After that the best I can do is inspect every other outlet/light ficture etc and make sure everything is as it should be.
trane xr90 3 blinking red lights after filter change murphyje HVAC 1 10-30-2012 03:33 PM
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 06:37 AM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Outlet and lights in a shed RegeSullivan Electrical 6 05-06-2009 03:34 PM
