Blind Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2008, 01:25 PM   #1
Question
blind outlet
garage has a covered outlet.behind it are 2 bare wires connected by auto screw on connectors,2whitel wires w/same type connector,& 2 black wires
with the same type connector.wires are not live. why is this covered outlet
there?
eddiemoney1 is offline   Reply With Quote
Old 10-17-2008, 03:27 PM   #2
DIY'r
ScottR's Avatar
why is this covered outlet there?
Only whomever installed it could say for sure...
Just to be sure, you mean wire nuts?
And by outlet, is there just a box, or is there a receptacle that was covered up?
Anyway, it's probably just a junction for a circuit. Maybe there was a receptacle or other device there at some point. If the wires are not live, then either the circuit is turned off at the breaker, it's on a switch, or it's just plain disconnected.
I don't think anyone here is going to be able to tell you what it's for without knowing where those wires go...
ScottR is offline   Reply With Quote
Old 10-17-2008, 04:00 PM   #3
the Musigician
DangerMouse's Avatar
or they just used an outlet box (they DID put a cover on it, yes?) as a junction box.
DM
Old 10-17-2008, 04:48 PM   #4
Rewards Points: 83
Careful with this one, but it might be a 220 circuit that as been capped and killed that fed an air compressor or the like. But without tracing the wires or doing some more investigation, who knows?
Bubbagump is offline   Reply With Quote
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
