Blackened (burned?) Light Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 01-18-2010, 10:03 PM   #1
Blackened (burned?) light bulb
The bulb in one of the ceiling fans blew yesterday (kind of went out with a whimper actually) and when I pulled off the globe today to change it the inside of the bulb looked charred. Prior to that the lights on the first floor were flickering - all of them, on at least 2 different circuits.
Could the two be related, and if so - whats exactly is going on to cause both instances? I've done a little reading into the flickering and from what i can gather there is something loose or arcing somewhere along the line which is causing the flickering. The blackened bulb I've never seen though and searching for 'black light' on google doesnt do much =p
cellophane is offline   Reply With Quote
Old 01-19-2010, 10:07 AM   #2
Rewards Points: 1,418
It is not unusual for the inside of the bulb to be blackened.
More importantly, and probably with more difficulty, you need to find a loose connection. If any (incandescent) lights flickered more brightly than they should be then fixing the loose connection (in a neutral line) is much more important and critical and everrything other than an incandescent light (includes microwave ovens since they contain electronics) needs to be unplugged from the affected circuits un til it is fixed.
There are so many places to look that I can't describe them all without writing a treatise; calling an electrician would be the best bet if you don't already know some of the troubleshooting techniques.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
How to remove light bulb casing rhymer59 Electrical 6 03-10-2009 10:26 PM
Do they make light bulb converters that will still allow a light bulb? jimithing78 Electrical 15 11-29-2008 12:57 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
Do I need training to change a light bulb? Mechelle Electrical 11 08-13-2008 08:26 AM
