Black X On Yellow Card On Power Line - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2009, 06:55 PM   #1
DIYer
Black X on Yellow Card on Power Line
Any of you all know what it means when there's a small (4 inch maybe) card mounted at the top of a power pole, with a black X on a yellow background on it?
I've seen these around here since I was a kid and always wondered what they meant. Only some poles (maybe one out of 20 or 30) have it.
Gigs is offline   Reply With Quote
Old 05-27-2009, 06:37 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
I've seen that too, except the ones I've noticed have had X,Y, & Z tags. My guess is that they are identification tags to the POCO for the X, Y, Z legs of the high voltage transmission lines.
Kyle
Old 05-27-2009, 08:52 AM   #3
I always thought they were phases A, B, and C
This is kind of interesting
http://www.jea.com/about/pub/downloa...ansformers.pdf
rgsgww is offline   Reply With Quote
Old 05-27-2009, 09:09 AM   #4
Rewards Points: 2,350
The phases can be labeled anything. A, B, C... X, Y, Z.... 1, 2, 3... Dog, Cat, Pigeon. Doesn't matter as long as they have a set standard.
Old 05-27-2009, 09:25 AM   #5
joed's Avatar
Rewards Points: 11,548
Hydro here lables them blue, white and red. If you look on the poles you will see the blue, white and red dots indicating which order they are on that pole. White is always the middle one.
Old 05-27-2009, 11:39 AM   #6
DIYer
I'm not sure this is that since I've only ever seen the X... I will take a picture of it on my phone and post it here soon.
Old 05-27-2009, 01:08 PM   #7
Rewards Points: 266
Gigs I've wondered that since I was a kid. I've only seen the X too... I've only seen it on older poles used for subtransmission so from 34.5 up to around 115 kv power lines. I don't think it is for phasing either.
For the others that never seen it before it looks kind of like this: (courtesy of paint
junkcollector is offline   Reply With Quote
Old 05-28-2009, 07:22 PM   #8
DIYer
Here is a picture.
Sometimes the X faces away from the road, which is even stranger.
Old 05-28-2009, 07:31 PM   #9
Here is a picture.
Oh, that! That's just means you have one strike on the Family Feud...
Old 05-28-2009, 07:34 PM   #10
DIYer
Old 05-28-2009, 09:17 PM   #11
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Way out in the country, that would be a target.
I used to see the porcelain insulators shot up all over the place.
Old 05-28-2009, 10:30 PM   #12
Rewards Points: 502
I've always wanted to know why some poles have a metal galvanized 1/2 pipe on them, go up about 6' then have an angled cap.
I'll see if I can get a photo of it.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 05-28-2009, 10:34 PM   #13
Licensed Pro
That's providing physical protection for wires running down the pole, usually phone lines.
Old 05-29-2009, 02:50 AM   #14
Rewards Points: 1,016
Here is a picture.
I think it's something to do with the aliens. Next time I am abducted I'll ask them.
Old 05-29-2009, 04:47 AM   #15
Rewards Points: 502
Except that, it only goes about 6' up the pole from the bottom. and there are no wires going in or out of the pipe.
It is not the same as the protective rubbery/plastic cover that I see used for underground service.
-Andrew
DIY hobbiest
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
power line noise sciguy125 Electrical 5 12-02-2007 02:39 PM
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
