#1 |
Black White and Red
I have wiring that I'm trying to connect to an outlet that has a hot black, hot red, and neutral white. My outlet screws are gold, silver and green. What goes where? I'm used to black, white, and copper. I would prefer this to be a grounded outlet - is that a possibility?
Thanks in advance for any help. |
#2 |
Black White and Red
Is this outlet(either top or bottom) controlled by a wall switch?
#3 |
Licensed electrician
Black White and Red
Did you remove a recpetacle that was there previously? Is the tab between to 2 brass screws missing?
Red can be used as a switched hot or to feed a switch. |
#4 |
Black White and Red
Yes it is connected to a wall switch. I removed a light that was there several years ago and capped the wires until I finished a lengthy remodel, and I'm finally getting back to the outdoor lighting. I don't remember the colors of the old light's wires. The outlet is new, so the bridge (tab) is still in place on the outlet.
#5 |
Black White and Red
White: silver screw
Black: Brass screw(top or bottom depending on which one you want switched) Red: Other brass screw. Bare: ground Break tab between the two brass screws. If you have a volt meter, I would test before you hook it up though. http://www.electrical-online.com/wir...doutletsp1.htm Last edited by jerryh3; 04-01-2008 at 09:44 PM. |
#6 |
Black White and Red
Thanks for your help - but one problem - there's no bare wire to use for the ground. Does this mean that I just won't be able to use any electrical eqipment that needs a three prong outlet?
#7 | |
Black White and RedQuote:
The ground pin will go nowhere and will not provide your "safety" ground. One option is to install a GFCI outlet, but it will not be 1/2 switched and you would cap off the red wire. Also they are tough to stuff into old small boxes. Another option would be to install a GFCI breaker to protect the entire circuit. Then you could install the 3 hole outlet. |
| Display Modes | |
