Is Black Tape REQUIRED? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 06:50 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by tomstruble View Post
i always see it on old work with the 2 fuzzy black wires and a glass wire nut
glass wire nuts?
I have seen ceramic wire nuts. They are for high temp conditions. The last thing you would want to use with them is tape? it would melt.
Before wire nuts, joints used to be soldered and then taped.
While the wire nuts currently used are pretty decent, I suppose their might have been time in life where the nuts were not so dependable so the guys taped them on to be sure they wouldn't come off. The problem with that is the tape really doesn't keep them tight so the joint would have come loose anyway.
Old 09-19-2010, 06:53 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
must be ceramic then nap....which is a type of ....
Tom Struble is offline   Reply With Quote
Old 09-19-2010, 07:14 PM   #18
nap
You talking to me?
nap's Avatar
glass is a type of ceramic but ceramics are not a type of glass.
even with that, most lay people do not consider glass to be a ceramic. Most common ceramics have a crystalline structure while glass has an amorphous structure.
when you say glass, most people think clear or at least opaque. Common ceramics are not translucent nor opaque.
common ceramics are also formed by molding a slurry of water and the ceramic material and are then fired to harden them. Glass is created simply by using heat to melt the ingredients into a semi-solid which is them molded and allowed to cool.
and yes, I am sure you are aware of all of this but if I must rebut a statement, this is what you get.
The Following User Says Thank You to nap For This Useful Post:
Tom Struble (09-20-2010)
Old 09-19-2010, 07:20 PM   #19
the Musigician
DangerMouse's Avatar
*sigh* all right you two......
DM
Old 09-19-2010, 09:23 PM   #20
nap
You talking to me?
nap's Avatar
DM
I'm just playing. Hopefully tom took it that way. He's one of the good guys, like you DM.
Old 09-19-2010, 10:34 PM   #21
" Euro " electrician
frenchelectrican's Avatar
There is not very many spot I will use the black tape on wirenuts that is pretty rare for me do it only one of few locations I will use is on the motour peckerhead { motour junction box } and one or two other locations if have high viberation situation.
A nick on the conductor insulationg I may use it to fix up otherwise use the judgement call on that one.
Merci.
Marc
Old 09-19-2010, 11:17 PM   #22
Just remember...the black tape is for hots
You need to use white tape for neutrals
And green tape for grounds
Don't mix them up
Old 09-20-2010, 12:51 AM   #23
Don't mix them up
Yeah but some peoples like me I have quite few diffrent tape colours so I can able use any of them as long I know which one is correct.
Hot is any colour unless listed below which it must used.
Netrual typically white or grey
Ground Green tape or green with yellow strip tape.
That is for North American colours the European have diffrent colour foramt.
Oh yeah there is nice gotcha if this in a cable yeah it can remarked any size but indivual conductors no unless it is larger than 16mm˛ { #6 AWG } then you can do it.
Merci,
Marc
Old 09-20-2010, 10:10 AM   #24
zpm
yeah, right
Don't mix them up
Just use clear tape and you don't have to worry about it.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 09-20-2010, 10:25 AM   #25
Just call me Andrew
Rewards Points: 1,020
Just to be safe, I use one full roll of electrical tape on every wire nut.
Andrew
secutanudu is offline   Reply With Quote
Old 09-20-2010, 10:30 AM   #26
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Don't mix them up
Here in Canada, we use hockey tape. Comes in all colors.
j/k but it would probably work well. LOL
Old 09-20-2010, 01:29 PM   #27
OK...I'll bite. Is there some functional problem with using tape? While I can see that it takes a little time to install, and can make later repairs and upgrades a bit more time consuming, it is also a small level of protection against foreign objects entering the wire nut. While I probably would not want to pay an electrician for the time to add the tape, I count this as one area where DIY might be an advantage...we are willing to spend extraordinary amounts of time for marginal improvements.
What am I missing here?
oberkc is offline   Reply With Quote
Old 09-20-2010, 01:33 PM   #28
Just call me Andrew
There's nothing wrong with taping the joints...it doesn't make things LESS safe. It's just completely unnecessary. If the wire nut is installed correctly, it will NOT come off. Meaning the tape is useless.
In order for the tape to actually provide any function, the wirenut would have to be incorrectly installed, in which case, it's going to fall off when the tape gets old and brittle anyway.
Andrew
Old 09-20-2010, 01:34 PM   #29
nap
You talking to me?
nap's Avatar
I don't see it as providing any benefits and I hate the goo it leaves if you ever have to get back into that joint.
As to anything falling into the nut; you aren't supposed to have foreign materials in the junction box to begin. So, if you follow that rule, you don't have to worry about the tape being needed.
any claim of a benefit can be countered with:
make the joint properly and you will not need the tape
Old 09-20-2010, 01:52 PM   #30
Yeah, right! I wish all the electricians who wired my house followed that rule! I am amazed at amount of crap in EVERY box I opened at my house. I just figured that vacuuming electrical boxes was another area that a DIYer was willing to do but not worth the time for the professional electrician.
Some people like belts and suspenders. Just in case.
Thanks for the response.
Using 14/3 with black and red hot = code? hellothere123 Electrical 7 09-20-2010 09:20 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Roof heat tape installation options daroepke Roofing/Siding 0 06-25-2010 12:36 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 10:27 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 11:53 AM
