Is Black Tape REQUIRED? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 10:56 AM   #1
the Musigician
DangerMouse's Avatar
Is black tape REQUIRED?
Is black tape REQUIRED or is it just "suggested" on wire nuts inside junction boxes?
Thanks!
DM
Old 09-19-2010, 11:11 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Never required OR suggested.
The Following User Says Thank You to Speedy Petey For This Useful Post:
oh'mike (09-19-2010)
Old 09-19-2010, 11:26 AM   #3
Rewards Points: 64
Thanks!
DM
Where do these myths come from?
J. V. is online now   Reply With Quote
Old 09-19-2010, 11:32 AM   #4
the Musigician
Good, Thanks Petey.
DM
Old 09-19-2010, 11:32 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 152
DIY Forums!
The Following User Says Thank You to jbfan For This Useful Post:
J. V. (09-20-2010)
Old 09-19-2010, 11:37 AM   #6
the Musigician
Yup, for example: Wiring 4 lights to 1 switch...Please help!
Posts #4 and #6.....
DM
Old 09-19-2010, 11:42 AM   #7
DM
Yup. Typical non-professional giving advice in all sorts of forums.
Old 09-19-2010, 11:44 AM   #8
the Musigician
I've always done it, and I've always wrapped black tape around the screws on outlets and switches as well!
Overkill or basic paranoia? LOL
DM
Old 09-19-2010, 11:48 AM   #9
Yes.
There is nothing inherently wrong with doing it, it's just wrapping wire nuts screams handyman/DIY.
Old 09-19-2010, 01:40 PM   #10
Electrician
Rewards Points: 760
The only time i ever tape my wirenuts is when useing a big wire nut with big wire(like #8's). Probably don't have to but the few times i run into this situation i have done it.
Tape on any other joint screams DIY like other people have said.
darren is offline   Reply With Quote
Old 09-19-2010, 01:47 PM   #11
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
I've seen electricians use tape on the screws but not wire nuts. The screws is mostly a safety thing. If you are in middle of renovations and the plates are all off nothing like getting a ZING when reaching for that light switch in the dark and your fingers find themseles between the two screws.
I will sometimes tape the wires together before they enter the wirenut, as to hold them together better for when I push the wires in the box. Normally if it's like 4 wires on one nut, where it becomes harder to work with.
Now speaking of black tape, is it required to wrap the wire when it enters a box, as to protect it from the edges? I've seen this done a lot too. I guess if you're really anal you could use the same clips that are used when a wire enters the electrical panel.
Old 09-19-2010, 01:52 PM   #12
the Musigician
ALL of my wires in and out of ALL of my junction boxes, fixture boxes, etc. have cable clamps.
I DO believe it's a requirement, but as always, I may not know the difference between my posterior and a spherical opening on a horizontal plane devoid of all mineral substances in this case.
DM
Old 09-19-2010, 02:36 PM   #13
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Thanks!
DM
not required, suggest, or desired and if you do it anymore I'm going to come up there and black tape you to the mailbox post. Then watch as you try to get that black goo off.
Old 09-19-2010, 07:16 PM   #14
jlhaslip's Avatar
Rewards Points: 396
I'll wrap tape on switches/plugs that are exposed when I can't cut the power to them. Don't recall ever taping a Marrete.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 09-19-2010, 07:42 PM   #15
Tom Struble's Avatar
Rewards Points: 2,002
i always see it on old work with the 2 fuzzy black wires and a glass wire nut
Tom Struble is offline   Reply With Quote
Using 14/3 with black and red hot = code? hellothere123 Electrical 7 09-20-2010 10:20 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 09:36 AM
Roof heat tape installation options daroepke Roofing/Siding 0 06-25-2010 01:36 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 12:53 PM
