Black Goo For Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2006, 11:03 AM   #1
Black Goo for wiring
When I had my dormer done last year, the holes where the wiring ran through the framming were "caulked" with some black goo. I'm assuming it is for code.
What is this stuff ? Is this available at Lowes/Home Depot ?...never looked
Thanks,
Scott
Scott_K is offline   Reply With Quote
Old 03-01-2006, 05:16 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Possibly black plastic roofing cement for a waterproof seal. It comes in all size cans from pints to 5-gallons. Very sticky stuff, and it can seal in the rain, wet or dry.
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-02-2006, 06:38 PM   #3
joed's Avatar
Rewards Points: 11,560
If the holes were in top or bottom plates it should have been fire stop caulk. The stuff I have seen is usually reddish color. It prevents fire in the wall cavity from escaping and spreading to the attic.
Old 03-02-2006, 07:24 PM   #4
Long-Time DIYer
Joed is right. I was wrong.
But like Joed, the fire stop stuff that I've seen is reddish, not black, but that may be another kind. Call the electrician that installed the wiring to find out.
Mike
Old 03-03-2006, 11:25 AM   #5
Thanks for the feedback. I talked to a fireman. He said that it's used for fire saftey. Helps to keep fires from breathing and spreading.
Copper to Black Iron BigJimmy Plumbing 1 07-23-2007 09:43 PM
Black wood putty JOHNL Carpentry 2 04-27-2007 11:35 AM
Black Metal Roof??? Goat66 Roofing/Siding 2 01-31-2007 11:58 AM
Paint/seal over black mastic KBO123 Flooring 1 12-06-2005 03:11 PM
Williams wall heater produces black smoke skark_burmer HVAC 2 02-24-2005 08:15 PM
