Biggest Au Wire In 1.5 Pvc - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 01:17 PM   #1
liscenced electrician
Rewards Points: 538
biggest au wire in 1.5 pvc
I ran 1.5 pvc to my detached garage. What is the biggest aluminum wire I can fit with 2 hots a neutral and a ground. Thanks -jimmy
jimmy21 is offline   Reply With Quote
Old 07-14-2009, 05:10 PM   #2
Rewards Points: 20
This is a good calculator
http://www.cerrowire.com/default.aspx?id=49
dcopps is offline   Reply With Quote
Old 07-14-2009, 06:56 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Are you sure you want to use solid gold wire?
Old 07-14-2009, 09:27 PM   #4
Idiot Emeritus
Rewards Points: 1,492
One thing about AU (gold) wire, a small wire would conduct a LOT of current!!
Seriously, if you're using either THWN or XHHW, the codebook says you can get 4-2/0s in a 1-1/2 schedule 40 PVC conduit. Aluminum or copper, it doesn't matter. It also says you can get 3-3/0s in, but if you figure cross-sectional area, the biggest ground you could get is a #8. Useless with 3/0s.
That's what the codebook says, it doesn't mean you can actually pull it though!
If it's less than 100', and not more than two 90s and you use lots of lube, it'll probably go in. When you're done, you'll know you've been in a fight though!
A while ago, I pulled 3-#1s, 1-#2, 1-#6, and some controls in a 1-1/2 about 130', with two 90s. It went in alright, but it made a 1200 lb. tugger work a bit. The guy feeding knew how to pull wire, otherwise it would have been much harder.
Rob
micromind is offline   Reply With Quote
Old 07-14-2009, 09:48 PM   #5
Rewards Points: 150
Mmm.. wouldn't you size your wire to your needs first and then size your conduit?
Gary
Gary_602z is offline   Reply With Quote
Old 07-14-2009, 11:23 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Gary
Useally that is correct way but somecase with exsting set up we have to really watch the conduit size but for large conductors the smallest one I will use is 1.5 inches or larger.
This moring I ran 4 inch conduit with 4X500KCM's { 240mm} with two 90 ells plus two 45 ells it was kinda borderline with our med size tugger (*3KG rating )( I did install very large sweep ell in there in first place that make the diffrence there )
Merci,Marc
Last edited by frenchelectrican; 07-16-2009 at 12:39 AM. Reason: * please read my next comment for fix up the goof there sorry about that
Old 07-15-2009, 01:02 AM   #7
Rewards Points: 2,350
Originally Posted by frenchelectrican View Post
This moring I ran 4 inch conduit with 4X500KCM's { 240mm} with two 90 ells plus two 45 ells it was kinda borderline with our med size tugger (3KG rating )( I did install very large sweep ell in there in first place that make the diffrence there )
Merci,Marc
3 kg? That's the weakest tugger I have ever heard of! I have a small tugger that will peak 3000 lbs. You should take that thing back and get one that can pull wire, and is properly rated, in newtons or pounds
Old 07-16-2009, 12:38 AM   #8
Opps I should say 3,000 KG I was not pay attetion to the typing sorry about that { I did have a long day so it will get me if not carefull }
Merci,Marc
New Stove, old wires - 2 wire vs 3 wire DIYGST Electrical 22 03-02-2009 04:13 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
