Big Question--can I Pull From Serice Disconnect? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 01:41 PM   #1
ericmunyon12345's Avatar
Big question--can i pull from serice disconnect?
Ok, I want to add a flood light on a pole by my H board. (Power goes from there to house and barns.) on the board is the meter, and three service disconnect panels. (Tell me if that's what they're called: large box with hinged door that only has one 100 or 200 amp breaker.) is it possible to add a sub panel next to one of these for branch circuits to run and outdoor receptacle and flood light?
It's a box similar to this. I haven't opened the cover, but I'm sure all that's in it are service conductors.
ericmunyon12345 is offline   Reply With Quote
Old 07-03-2013, 02:38 PM   #2
MarginallyQualified
Rewards Points: 2,464
How many meters do you have on this property?
On their own? A Disconnect.
Like in your picture above? Meter/Main
Depends. (on a bunch of things)
Old 07-03-2013, 05:04 PM   #3
. What I want to do is a tap to a two space sub (like sq d 2024).
Old 07-03-2013, 06:49 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
NO. There is no easy way to tap anything off this meter main.
Basically it would need to be replaced with a meter/main/feed-through panel.
Speedy Petey is online now   Reply With Quote
Old 07-03-2013, 09:27 PM   #5
I just pulled that pic from google. What I have is one main box with a lever disconnect/generator lockout, then three boxes, each with one breaker of 100 or 200 amps. So it's on the load side of the service. Someone told me I could tap from that to a sub panel to feed light and recep. .??
Old 07-04-2013, 02:18 AM   #6
Electrician
Rewards Points: 150
Speedy Petey is mistaken. There are a number of ways to pull power from that picture. And there would be a number of ways in your setup. I need clear pictures that enlarge well. Similar to the OP picture. Especially of the first box that has an OverCurrent Protection Device (breaker or fuses).
We're looking for a box that has lots of room in it. And one that has lots of headroom between it's actual load and the size of it's OCPD.
It would be nice to know the actual amp draw of the light and receptacle. And a wish list of anything you want to power from there in the future.
Glennsparky is offline   Reply With Quote
Old 07-04-2013, 07:07 AM   #7
For real??? You think you can safely and complaintly tap off that meter/main the OP??
WOW!
Old 07-04-2013, 07:08 AM   #8
Well then your box is not that similar.
I would need to see pics with the covers open (NOT the meter box itself) to even begin to give any advice.
Old 07-04-2013, 07:14 AM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
From that picture, it could be done...
Cheaply? Probably not...
Easily? For an electrician...sure
However, all this talk doesn't matter unless we see real pics. I have a feeling from the description, it wouldn't be as easy as the OP.
Old 07-04-2013, 01:21 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,942
WOW!
Why couldn't you use split bolts or double-lug adapters to run a small subpanel off the load side of that breaker?
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 07-04-2013, 01:26 PM   #11
That's kind of what I'm thinking. I'll try to get some pics up, but I may not have time to get pics with covers off until sat.
Old 07-04-2013, 07:15 PM   #12
biggles's Avatar
panel has to be right on the other side of the wall drill yourself a hole
Old 07-04-2013, 08:03 PM   #13
I'm going to start a new thread with actual pics of the job. Thanks, and I'd really appreciate help.
Magnet pull force question here jratftcc Electrical 6 05-17-2013 08:57 AM
Wire size question wyblep Electrical 10 05-16-2013 09:56 PM
A/C Disconnect question mikem201 HVAC 19 03-17-2013 09:06 AM
Grounding question tmbleweed Electrical 11 01-12-2011 10:27 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
