Big Hole - Electrical - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 09:21 AM   #1
big hole
im installing a new fixture and the existing whole is to big what is the piece i need to put between the new fixture and the ceiling called?
mrsfixit13 is offline   Reply With Quote
Old 07-25-2011, 09:25 AM   #2
Licensed electrician
The electrical code requires any gap greater than 1/8" to be repaired. What is your ceiling made of?
Old 07-25-2011, 09:30 AM   #3
sheet rock, i just need the name of the decorative ceiling ornamate that u slide up ove a light fixture
Old 07-25-2011, 09:31 AM   #4
Licensed Pro
Ceiling medallion
Old 07-25-2011, 09:33 AM   #5
not that i have that problem we were just talking over morning coffee and cant think of the specific name fr that piece!
Old 07-25-2011, 12:05 PM   #6
Rewards Points: 87
The problem is run-on sentences and lack of punctuation.
A picture would be most helpful.
George6488 is offline   Reply With Quote
Old 07-25-2011, 04:44 PM   #7
Rewards Points: 1,418
A cup or cone shaped piece usually less than 6 inches in diameter is a canopy.
A flat (or decoratively contoured) disk is a medallion.
Old 07-25-2011, 05:29 PM   #8
Rewards Points: 1,214
"This is Electrical DIY not English class" lighten up teach.
COLDIRON is offline   Reply With Quote
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 06:55 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
