Is This The Best Way To Wire A Floor? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 10:44 PM   #1
Question
Is this the best way to wire a floor?
Hi,
Preparing to run my wiring before i have an electrician come verify all is proper. I have attached a screenshot of my amateur mspaint drawing. It can be seen larger here: http://shiftace.ca/electrical.html (99.5% of folks don't read my site name proper the first 4 times)
There is a shower steamer that will have its own breaker, and i believe the same thing with the tub motor. The same also with the smoke/CO detector i believe (not in the pic).
One question is, i have three lights in the bathroom, would it be okay to combine those three lights with the nine outlets on the same 15amp breaker?
And the main question i have... is this the sanest way to wire the floor, or does anyone have any suggestions? Thanks for reading this and for any input.
GoJetsGo is offline   Reply With Quote
Old 10-25-2012, 11:18 PM   #2
Licensed electrician
Rewards Points: 1,794
It would help if your location was filled out. From your use of ensuite I suspect Canada.
Old 10-26-2012, 05:12 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
The URL he references is a Canada site.
Coastal South Carolina
Old 10-26-2012, 05:48 AM   #4
Master Electrician
For the code. Any receptacle installed in a washroom has to be 1m but not less than 500mm from a tub or shower as measured horizontally without running into a wall. The 500mm is for small bathrooms and the inspector may ding you if your not at the 1m. Bedroom receptacles need afci protection and tamperproof receptacles. Smokes need to be on a general lighting circuit. Donrt forget you gfci's in the bathroom.
Personally I would run a seperate circuit for the bathroom receptacles. It will save you a ton of headaches resetting breakers(hairdryer draws 15a). Or run a 20a circuit for them. Remember though you can't have lights on a 20a circuit.
Good luck!
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
GoJetsGo (10-26-2012)
Old 10-26-2012, 11:38 AM   #5
Rewards Points: 204
But he's a Jets fan. How sick is that?
Old 10-26-2012, 01:05 PM   #6
Master Electrician
I haven't figured out why we don't have an NFL team in Toronto. Makes more sense than having the bills here to play 2 or 3 games a year. They have to be itching to get out of buffalo anyways
Old 10-26-2012, 01:56 PM   #7
No surprising since he's in Winnipeg.
Rewound98 is offline   Reply With Quote
Old 10-26-2012, 05:48 PM   #8
A "Handy Husband"
rjniles's Avatar
John,
Winnipeg Jets = hockey
NY Jets = football
Old 10-26-2012, 11:31 PM   #9
You bet eh! 8)
Old 10-26-2012, 11:47 PM   #10
Good luck!
Thanks Andrew.
Okay, i have added an outlet on the south wall of the bathroom to be within the 50-100cm distance from the tub w/no obstructions.
Also, i have changed the circuit from all 9 outlets to the now 4 of the bathroom outlets, and put the three lights with the 6 outlets in the bedroom/sitting area.
Does this make a bit more sense now? Or is it unorthodox to have one of the five bathroom receptacles running with another circuit?
And the AFCI, does that have to just include the receptacles, or the lights too? This might change how i run everything up here.
Thanks again!
Old 10-26-2012, 11:54 PM   #11
Electrician
Rewards Points: 802
Bedroom plugs will need to be arc fault protected, put nothing else but the bedroom plugs on this circuit.
Depending on what you are putting in for lights you could use one circuit for all the lights and the plugs in the washroom, your smoke detector will need to go on the lighting cct. If it were me I would try and put the bathroom plugs on there own circuit.
Dedicated circuit for steam shower and tub motor is good idea, they may have to be GFI protected. I would have to look it up to give you an exact answer.
What's the point of the plug next to the toliet and the one next to the tub, all bathroom plugs I have seen are near the sinks?
darren is offline   Reply With Quote
Old 10-27-2012, 07:01 AM   #12
Master Electrician
It's not a requirement its a nono do not put a plug there. I worded it poorly. It's a minimum clearance distance. Sorry bout that.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
