-   -   Is this the best way to wire a floor? (http://www.diychatroom.com/f18/best-way-wire-floor-161180/)
GoJetsGo 10-25-2012 10:44 PM
1 Attachment(s)
Hi,
Preparing to run my wiring before i have an electrician come verify all is proper. I have attached a screenshot of my amateur mspaint drawing. It can be seen larger here: http://shiftace.ca/electrical.html (99.5% of folks don't read my site name proper the first 4 times)
There is a shower steamer that will have its own breaker, and i believe the same thing with the tub motor. The same also with the smoke/CO detector i believe (not in the pic).
One question is, i have three lights in the bathroom, would it be okay to combine those three lights with the nine outlets on the same 15amp breaker?
And the main question i have... is this the sanest way to wire the floor, or does anyone have any suggestions? Thanks for reading this and for any input.
Jim Port 10-25-2012 11:18 PM
It would help if your location was filled out. From your use of ensuite I suspect Canada.
rjniles 10-26-2012 05:12 AM
The URL he references is a Canada site.
andrew79 10-26-2012 05:48 AM
For the code. Any receptacle installed in a washroom has to be 1m but not less than 500mm from a tub or shower as measured horizontally without running into a wall. The 500mm is for small bathrooms and the inspector may ding you if your not at the 1m. Bedroom receptacles need afci protection and tamperproof receptacles. Smokes need to be on a general lighting circuit. Donrt forget you gfci's in the bathroom.
Personally I would run a seperate circuit for the bathroom receptacles. It will save you a ton of headaches resetting breakers(hairdryer draws 15a). Or run a 20a circuit for them. Remember though you can't have lights on a 20a circuit.
Good luck!
J. V. 10-26-2012 11:38 AM
But he's a Jets fan. How sick is that?
andrew79 10-26-2012 01:05 PM
I haven't figured out why we don't have an NFL team in Toronto. Makes more sense than having the bills here to play 2 or 3 games a year. They have to be itching to get out of buffalo anyways :laughing:
Rewound98 10-26-2012 01:56 PM
No surprising since he's in Winnipeg.
rjniles 10-26-2012 05:48 PM
John,
Winnipeg Jets = hockey
NY Jets = football
GoJetsGo 10-26-2012 11:31 PM
You bet eh! 8)
GoJetsGo 10-26-2012 11:47 PM
1 Attachment(s)
Good luck!
Thanks Andrew.
Okay, i have added an outlet on the south wall of the bathroom to be within the 50-100cm distance from the tub w/no obstructions.
Also, i have changed the circuit from all 9 outlets to the now 4 of the bathroom outlets, and put the three lights with the 6 outlets in the bedroom/sitting area.
Does this make a bit more sense now? Or is it unorthodox to have one of the five bathroom receptacles running with another circuit?
And the AFCI, does that have to just include the receptacles, or the lights too? This might change how i run everything up here.
Thanks again!
darren 10-26-2012 11:54 PM
Bedroom plugs will need to be arc fault protected, put nothing else but the bedroom plugs on this circuit.
Depending on what you are putting in for lights you could use one circuit for all the lights and the plugs in the washroom, your smoke detector will need to go on the lighting cct. If it were me I would try and put the bathroom plugs on there own circuit.
Dedicated circuit for steam shower and tub motor is good idea, they may have to be GFI protected. I would have to look it up to give you an exact answer.
What's the point of the plug next to the toliet and the one next to the tub, all bathroom plugs I have seen are near the sinks?
andrew79 10-27-2012 07:01 AM
It's not a requirement its a nono do not put a plug there. I worded it poorly. It's a minimum clearance distance. Sorry bout that.
