Best Way To Upgrade Ungrounded Outlets To Grounded? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2011, 02:11 PM   #1
Rewards Points: 27
Best way to upgrade ungrounded outlets to grounded?
I'm in a 1950s house that has quite a few 2-prong ungrounded outlets, and I want to upgrade them all to 3-prong grounded ones. There are already some 3-prong outlets in the house, so I'm assuming that at least some of the wiring in the house includes a ground wire.
For the ungrounded outlets, what's the basic procedure? If no grounding wire is present, I have to run one to the box, correct?
mikemcd is offline   Reply With Quote
Old 09-12-2011, 02:14 PM   #2
Code05's Avatar
Rewards Points: 1,104
Yes or provide GFCI protection and label accordingly.
Code05 is offline   Reply With Quote
Old 09-12-2011, 02:22 PM   #3
Rewards Points: 6,652
What is the current wiring method in the house? For the era if they used armored cable, and it had a fuse panel originally, the armor would be the ground return path in the old system. If needing grounded outlets for electronics, such as a computer, HD tv, etc, how hard would it be to pull new romex to update? Also, has the breaker panel been updated from older style fuse, or breaker panel. That you can post pictures of.
Old 09-12-2011, 08:06 PM   #4
Knucklez's Avatar
Rewards Points: 942
i doubt that .. probably just replaced the old receptacle with a new one .. no ground
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-12-2011, 09:10 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Or a bootlegged ground. Should pull the receptacle out and check how it's wired to be safe.
Kyle
Old 09-12-2011, 09:58 PM   #6
Military Mom of 4
Snav's Avatar
I've discovered that even if it looks like it's all grounded - sometimes it's still not.
I have a ground outside that runs up the wall - but it connects to nothing. The inner wiring of the home has no ground but all previous outlets that the previous owners installed had a ground wired to them.
I use GCFI outlets and such as necessary - and sometimes I use a portable one that plugs in.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Ungrounded outlets white29 Electrical 2 05-31-2010 02:31 PM
Ungrounded outlets RJ75 Electrical 13 04-05-2009 06:51 PM
Outlets are not grounded...what to do about it? OldHouse963 General DIY Discussions 10 04-14-2008 08:36 AM
