Best Way To Splice A Wire Back Together - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 09:25 PM   #1
Best way to splice a wire back together
To do some work on a wall I am going to cut a 14/2 that runs through the wall joists. After cutting, the wire will be too short to splice back together. How is this best accomplished?
puttster
puttster is offline   Reply With Quote
Old 05-08-2012, 09:28 PM   #2
Just a DIY guy
Can you disconnect the wire at the end of its run and and pull it through the studs (wall joists) so you do not have to cut it?
What kind of work are you doing that requres wire cutting?
M3 Pete is offline   Reply With Quote
Old 05-08-2012, 09:29 PM   #3
Licensed electrician
Rewards Points: 996
You can either replace it between the two boxes or you are going to need to add two junction boxes and a short jumper cable between the new boxes.
Old 05-08-2012, 09:32 PM   #4
Just a DIY guy
And since the boxes are in a wall, the box covers must remain accessible after the wall is re-finished. So if you add two junction boxes, you will have two covers on the wall when you are done.
Thus, replacing the wire between the boxes is a better way to go, or what I suggested, to avoid cutting it at all.
Old 05-08-2012, 09:44 PM   #5
Rewards Points: 6,652
What, you do not have a cable stretcher? I mean come on now, everyone should have one in their tool kit. All kidding aside, how much distance are we talking, when it comes to the cut ends?
Old 05-08-2012, 10:52 PM   #6
Don't tease me with the cable stretcher, you know that is what I was looking for.
Some wall is getting removed so I can use the idea to unwire it from one of the boxes and pull it back through the studs. That's a good idea. When I'm done building there will likely be a detour back to the box so the wire will still be a little short. But by doing it this way I will only have to add one box, and I can probably use the one extra outlet anyway.
Thanks for the info folks!
Old 05-09-2012, 01:00 AM   #7
" Euro " electrician
frenchelectrican's Avatar
Just becarefull when you pull that out and when you do add a new box what room this will be serve due there is few area that is off limit if that circuit is used from other rooms.
The typical circuit can only stay in the rooms are
* Bathroom
* Kitchen
* Landury room
* Garage
Those circuit you can not tap and use them in other rooms at all so check it ahead of that.
Merci,
Marc
Old 05-09-2012, 07:31 AM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
I hope this is not how you did it.
Coastal South Carolina
Old 05-09-2012, 12:25 PM   #9
Just a DIY guy
A little duct tape and those are ready to put back in the box!
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 03:06 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 05:24 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
