Best Way To Route Wiring For Can Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 04:25 AM   #1
Rewards Points: 150
Best way to route wiring for can lights?
I am working on wiring a detached garage and last night installed 12 can lights in the ceiling of the office space above the shop. The joists are 2x12, under a gambrel style roof. No trusses if this matters.
My question is, what is the best way to route the wire for the cans? I wouldn't think drilling holes in the joists is a good idea, but I'm also unsure if stapling (with correct sized wire staples) on top of the edge of the joists are allowed.
I can upload a couple pics to show what it looks like in the attic area.. it's all wide open, no insulation or drywall up.
sheslostcontrol is offline   Reply With Quote
Old 01-10-2011, 06:20 AM   #2
Stay-at-home GC
Rat-runs or Strongbacks (2x4's nailed across the tops of the ceiling joists) Staple to the sides of the 2x4's
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-10-2011, 03:21 PM   #3
WaldenL's Avatar
Rewards Points: 268
Don't see a problem drilling holes in the joists for the wires, we're not talking about 8" holes here, shouldn't have any impact on the structure.
WaldenL is offline   Reply With Quote
Old 01-10-2011, 04:19 PM   #4
Scared Electrician
Saturday Cowboy's Avatar
Seconded
Up to 1/3 of a joist can be drilled with little strength reduction.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Wiring question - two lights with one switch... Cleon26 Electrical 3 12-28-2010 09:09 AM
4 wire occupancy switch wiring.. FLASHING lights?? darin00 Electrical 3 12-18-2010 07:38 AM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-20-2010 11:12 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
