Old 05-30-2012, 09:18 PM   #1
Best way to locate EMT conduit behind sheetrock?
I need to locate where an EMT conduit runs in the wall.
The conduit runs in the attic then it gets into a very tight spot where I can't trace anymore.
Somewhere along the edge of the exterior wall it must turn vertical and run downward. I need to determine where it runs down.
The conduit is a 1/2" EMT. The wall is a concrete block wall, then 1/2" furring strips, then 1-1/4" of sheetrock over it. The conduit runs in the 1/2" space between the block and the sheetrock.
The sheetrock is not actual sheetrock. It is a double ply with 1/2" gypsum board backing, then 1/2" of hand applied brown coat with a 1/4" top coat egg shell finish. I tried a typical stud finder and it's not telling me anything.
Any thoughts?
miamicuse is offline   Reply With Quote
Old 05-30-2012, 09:48 PM   #2
Licensed electrician
I thought some of the stud finders would detect rebar in a wall. I don't know how they would work on conduit.
Old 05-30-2012, 10:03 PM   #3
Missouri Bound's Avatar
Correct, some will locate metal as well as wood studs. I have a Stanley which is "supposed" to do that. ( I say that because I haven't used it on either metal stud buildings or conduit)
Do you want it your way or the right way?
Old 05-30-2012, 10:11 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
You might be able to do it with a FLIR, or try a metal detector on a whim, which is actually how the ground tracing equipment works, that utilities use to locate stuff. Here is a list of some other gadgets for tracing lines http://www.nextag.com/cable-tracer/stores-html
Also, if there is too sharp of a bend, or it snakes, which is doubtful, it would be hard to pull wire through when they did it originally. Can you post drawings for relation to the outlet & the conduit up in the attic where you lose it.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 05-30-2012, 10:16 PM   #5
Consider a cow magnet.
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 02:34 AM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
