-   -   Best way to locate EMT conduit behind sheetrock? (http://www.diychatroom.com/f18/best-way-locate-emt-conduit-behind-sheetrock-145413/)
miamicuse 05-30-2012 08:18 PM
3 Attachment(s)
I need to locate where an EMT conduit runs in the wall.
The conduit runs in the attic then it gets into a very tight spot where I can't trace anymore.
Somewhere along the edge of the exterior wall it must turn vertical and run downward. I need to determine where it runs down.
The conduit is a 1/2" EMT. The wall is a concrete block wall, then 1/2" furring strips, then 1-1/4" of sheetrock over it. The conduit runs in the 1/2" space between the block and the sheetrock.
The sheetrock is not actual sheetrock. It is a double ply with 1/2" gypsum board backing, then 1/2" of hand applied brown coat with a 1/4" top coat egg shell finish. I tried a typical stud finder and it's not telling me anything.
Any thoughts?
Jim Port 05-30-2012 08:48 PM
I thought some of the stud finders would detect rebar in a wall. I don't know how they would work on conduit.
Missouri Bound 05-30-2012 09:03 PM
Correct, some will locate metal as well as wood studs. I have a Stanley which is "supposed" to do that. ( I say that because I haven't used it on either metal stud buildings or conduit):whistling2:
gregzoll 05-30-2012 09:11 PM
You might be able to do it with a FLIR, or try a metal detector on a whim, which is actually how the ground tracing equipment works, that utilities use to locate stuff. Here is a list of some other gadgets for tracing lines http://www.nextag.com/cable-tracer/stores-html
Also, if there is too sharp of a bend, or it snakes, which is doubtful, it would be hard to pull wire through when they did it originally. Can you post drawings for relation to the outlet & the conduit up in the attic where you lose it.
Missouri Bound 05-30-2012 09:16 PM
Consider a cow magnet.
