Best Way To Find Out Which Breaker Belongs To The Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 07:24 PM   #1
best way to find out which breaker belongs to the circuit
hello,
i'm working on a house that has a full circuit panel and only about 5 breakers are labeled. short of shutting power down to the whole house, what's the best way to figure this out. i know there's specialty tools on the market, but is there another way...like purposely tripping the breaker through an outlet? any help is greatly appreciated. thank you!
-nate-
neight is offline   Reply With Quote
Old 12-11-2012, 07:32 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
plug in a radio and turn it up loud...
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (12-11-2012), Kpack (12-11-2012), Rochsolid (12-12-2012)
Old 12-11-2012, 07:37 PM   #3
Rewards Points: 12,818
Make sure to remove the batterys first.
jbfan (12-11-2012)
Old 12-11-2012, 07:39 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 816
And if you have kids....it's a good way to get them involved and teach them something at the same time.....
If you have boys and a couple of radios.....it's actually kind of fun....they make it into a game....
The plug in a lamp or radio....you turn off breakers until you find the one that kills the light/radio.....move to the next outlet.
Lights are easier.....you just turn everything one....then kill breakers until the lights go dark. In most cases, the lights will be in groups.
Where it get real fun is GFIC's.....there never seems to be any rhym or reason to how those are run.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
Kpack (12-11-2012), NJMarine (12-12-2012)
Old 12-11-2012, 07:53 PM   #5
the customer works from home. the trial and error method won't work, unfortunately. otherwise i'd shut the whole thing down.
Old 12-11-2012, 07:55 PM   #6
E2 Electrician
it will take you less than half an hour to label the panel, im sure the homeowner can deal with that.
The Following User Says Thank You to stickboy1375 For This Useful Post:
neight (12-11-2012)
Old 12-11-2012, 08:04 PM   #7
i'll give it shot. she does seem slightly more reasonable than most homeowners. it really is the best way....and that panel has to be labeled.
Old 12-11-2012, 11:35 PM   #8
Rewards Points: 528
And an extra radio can save a little time too(one station on talk another on music )
hidden1 is offline   Reply With Quote
Old 12-12-2012, 12:19 AM   #9
Rewards Points: 324
just buy a GB get-1200 ckt tracer.or digital ckt detective mod htp-6.only bad thing,only good on live ckts.
oleguy74 is offline   Reply With Quote
Old 12-12-2012, 12:29 AM   #10
DIY Enthusiast
sublime2's Avatar
Get yourself one of these;
http://www.amazon.com/gp/aw/d/B0002T...dir_mdp_mobile
You will find it useful.
sublime2 is offline   Reply With Quote
Old 12-12-2012, 12:30 AM   #11
Rewards Points: 506
Let's pretend you construct a no-load, short-circuit device with the intention of using it to trip a breaker. Then lets assume that not one single breaker trips. Now what are you going to do? Tear the house apart and look for burned wires, or a smoldering fire? Change out all the breakers with new?
Better to not take this approach.
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
Old 12-12-2012, 09:36 AM   #12
Rewards Points: 150
Lots of cell phone plans have unlimited Talk, or unlimited Mobile-to-Mobile, or unlimited Family Talk. If you have two phones on one of those kind of plans, you don't even need a radio.
By the way, girls work just as good as boys at this.
Dave632 is offline   Reply With Quote
Old 12-12-2012, 08:55 PM   #13
Rewards Points: 81
When I first moved into my house 20 years ago, I sketched out the entire house and mapped all of the electrical outlets and lights. I shut off breaker #1 and went around the house and noted what was on it. Turned #1 back on and went to #2, and so on.
Of course I have since lost the map, and it is probably obsolete anyway since the panel has been upgraded since. My memory and the labeling the electrician did are good enough to get the right breaker on the first try normally. A lamp, pencil and piece of graph paper are all you need - just don't lose the paper once you are done. I use a $4 tester just to make sure power is off and it is wired correctly when back on.
tev9999 is offline   Reply With Quote
Old 12-15-2012, 03:04 PM   #14
I mark the number on the back of the switch cover. Not perfect but works very well.
rodm1 is offline   Reply With Quote
Tags
trouble shooting
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-02-2012 12:20 AM
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
Is it possible to change Circuit breaker to Buss fuse socket type? njchen24 Electrical 8 08-07-2011 07:27 PM
Circuit Breaker, working in reverse dcwestcott Electrical 4 04-06-2009 04:03 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 04:09 PM
