Best Way To Connect This Under-cabinet Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 08:23 PM   #1
Rewards Points: 150
Best way to connect this under-cabinet light?
I'm having trouble with how to run wiring to this 3' T5 mounted under a cabinet in the shop. Hope this picture shows everything:
The fixture doesn't have cable clamp holes on the sides, only the ends and top. My thought was to run the wire to the end, but that leaves a long section exposed.. which can't be to code. Can't run it from the top since that is a storage area.
Suggestions?
sheslostcontrol is offline   Reply With Quote
Old 03-09-2011, 08:33 PM   #2
Master Electrician
Rewards Points: 3,916
No problem whatsoever going into the end.
brric is online now   Reply With Quote
Old 03-09-2011, 08:55 PM   #3
Rewards Points: 150
With the romex out in the open like that?
Old 03-09-2011, 09:25 PM   #4
Electrical Supplier
Rewards Points: 150
as long as the romex coming in is secured by an appropriate cable connector you are fine. You also would need to secure that romex to the stud at a reasonable point, in an appropriate manner to avoid damage to the romex.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 03-10-2011, 05:19 AM   #5
Master Electrician
No, you had better use RMC with THHN.
Old 03-10-2011, 06:00 AM   #6
Rewards Points: 150
How do I connect metal conduit into a plastic box with no threads? Or are you saying I have to rip out $500 in wire and redo it all with conduit? This will eventually be covered up w sheetrock.
Old 03-10-2011, 05:52 PM   #7
Master Electrician
It was a joke. What you are doing is fine.
The Following User Says Thank You to brric For This Useful Post:
sheslostcontrol (03-10-2011)
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 11:59 AM
light inside of a cabinet rustic Electrical 2 02-19-2009 08:50 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
