Best Undercabinet Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 07:46 AM   #1
Best undercabinet lighting
Could someone steer me in the right direction to some good under cabinet puck lighting. Probably want Xenon or LED and not halogen because of heat. Where can I find it? Thanks.
ingeborgdot is offline   Reply With Quote
Old 10-05-2009, 08:03 AM   #2
Rewards Points: 338
ingebordot, I like to use W.A.C. lighting
http://www.waclighting.com/USA/products/?categoryid=52 . They are available at electrical supply houses....
petey_c is offline   Reply With Quote
Old 10-05-2009, 01:00 PM   #3
Rewards Points: 1,016
I used halogen - too hot. If I had a do-over I would use LED.
Old 10-05-2009, 04:22 PM   #4
We will be having cabinets that are full overlay and I don't believe there will be any covering below that will hide the track for track lighting but the puck recessed in should work. What would I need for each kit?
Old 10-05-2009, 04:59 PM   #5
Remodeler
MinConst's Avatar
Best thing I've seen is the new LED strips. They are about 1/8" thick and self stick really cool and light up the areas very nicely. Do a search for LED lighting and you should find them. A little costly but really nice. Take tight curves and almost hide themselves.
Minichillo's Construction
I will never leave you hanging!
Web
One Man Shops
MinConst is offline   Reply With Quote
Old 10-06-2009, 12:00 AM   #6
Is there a brand I should look for?
Hardwire undercabinet lighting? theatretch85 Electrical 19 04-22-2009 02:29 AM
Roughing in Undercabinet Lighting theatretch85 Electrical 4 04-08-2009 08:23 AM
wiring for undercabinet lighting with walls open ahreno Electrical 3 03-28-2009 11:56 PM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 05:37 AM
Undercabinet lighting: What would you use? Karde Electrical 3 01-04-2009 11:26 AM
