Best Practices To Drill On Exterior Wall - Security Camera Install - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 06:28 PM   #1
best practices to drill on exterior wall - security camera Install
Hi,
New to this forum .
Just got my new security camera survillence kit and I would like to install some of the cameras on the outside of my home. I have a general Idea of the locations on where the camera's will be placed.
I would like to know what would be the best way to get the ethernet cables from outside to the inside to my home. My home is brand new and is a typical wood frame construction. I have checked with the builder and he said that that the outside studs are 2x6.
* what kind of drill bit should I use? I have drywall on the inside and OSB sheathing + some kind of cement/wood siding on the outside.
* should I drill through the studs or through the OSB + insulation + drywall.
* what kind of sealant I should be using. ?
* would I have any issues with the outside wall insulation?
* should I drill from the outside - in or inside-out?
any other suggesstion will be highly appreciated.
don_b is offline   Reply With Quote
Old 10-18-2012, 06:48 PM   #2
Framing Contractor
Rewards Points: 116
Not sure where you are located, but generally the best bet would be to drill from the basement if you have one. Find a point of reference like a window or something and check both inside and outside for any obvious obstructions.
sixeightten is offline   Reply With Quote
Old 10-18-2012, 06:58 PM   #3
I don't have a basement.
Old 10-18-2012, 07:11 PM   #4
Framing Contractor
Rewards Points: 116
Do you have an attic area that can be accessed? If so, you can find a good place to run the wire through by observing the unfinished side of the framing. This will also allow you access to the backside of the ceiling drywall to help assist with fishing the wire through to the inside.
Old 10-18-2012, 07:20 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
some security cameras are mounted under the roof eaves onto the soffit.
if you have access to an attic, the cables could be run from the outside into the attic.
from inside the attic your cables can run to their respective location. (ie: the monitor/recoding device)
hope this was a little helpful.
hmm, sixeightten beat me. typing too slooow. haha
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 10-18-2012, 07:47 PM   #6
I never have been to the attic but took a peek into it through the access door . there was ~ 25"-30" of insulation material all around. felt like a big snow fall..
I like the idea of getting the wire fished through the attic because the builder already has installed a ENT tubing from my on-q box to the attic to the crawl.
However, I am bit tense walking around in the attic.
Any tool I could use to walk around with such thick insulation.
How do I fish the wires from the soffit to the attic. is there some opening if i drill a hole in the soffit?
Old 10-18-2012, 08:03 PM   #7
Framing Contractor
Rewards Points: 116
After drilling a hole in the soffit, you can poke a piece of still wire up into the attic and locate this. Then tie the cable to the stiff wire and pull it back through the soffit. Navigating through the attic can be tricky. You will have to walk along each truss or ceiling joist. If you move slowly, you can find each one with your foot before putting your weight down. The spacing is usually consistent, so finding each one is pretty easy.
Old 10-19-2012, 07:15 AM   #8
raylo32's Avatar
Rewards Points: 1,244
Here's my outdoor cam setup.... ran the ethernet through the wall from inside above the ceiling to a weather tight box outside. From the box to the cam with watertight plastic housing as specified in the cam manual. All mounted up with SS tamper resistant hardware.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-19-2012, 05:46 PM   #9
thanks
Old 12-03-2012, 01:57 PM   #10
Rewards Points: 1,192
I use 1' x 8' pieces of " plywood to work in attics with insulation.
bobelectric is offline   Reply With Quote
Old 12-03-2012, 04:59 PM   #11
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
What Bob said. Just make sure it is not 1/4" plywood. Use 5/8" or better.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-03-2012, 05:09 PM   #12
RetiredSoldier's Avatar
Rewards Points: 27
Tamper resistant except for the plastic wiring cover. Might consider conduit for cut-resistance.
BTW, someone used the wrong sized joist hanger I believe.
RetiredSoldier is offline   Reply With Quote
Tags
drill , exterior wall , insulation; foam; wall , security system
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 10:53 AM
drilling into steel door all the way thru for inside security bar install docjlb Building & Construction 4 12-18-2010 05:48 PM
How to install a wireless security camera BIO Electrical 7 03-23-2009 10:59 AM
Security Light install on metal outbuilding Chevyscrounger Electrical 7 01-01-2009 04:13 PM
