Best LED Can Light Setup? Rule Of Thumb For Installation Spacing? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 04:51 AM   #1
Question
Best LED can light setup? Rule of thumb for installation spacing?
I'm nearly ready to begin installing new can lights in our master suite, and I'm thinking that I would like to use LED can lights (please stop me here if standard can lighting is advised). I would like some help here in selecting a can light and trim to install.
I'm currently thinking of using Juno IC21R Shallow 6" Cans with a Sylvania 70644 LED remodel lighting kit. Is this a good setup for bedroom, closet and bathroom? I plan on using a dimmer switch on all lighting circuits with these lights.
I'm also hoping to receive some advice about the suggested spacing for LED can lights. Is there a good rule of thumb to follow?
Thanks,
Kiel
Optical1 is offline   Reply With Quote
Old 12-24-2012, 05:32 AM   #2
Electrical Contractor
kbsparky's Avatar
Those Sylvania trims are great. As for spacing, that's up to you:
Depending on how much light you want, you could space `em 4 feet apart, or 64" or 80". Those values are multiples of 16" -- the standard spacing of ceiling joists.
IF your joists/trusses have 24" spacing, then your spacing should be in multiples of 2 feet, such as 4 or 6 feet.
By using spacing like that, it doesn't matter whether your rows are parallel or perpendicular to the joists, they will always fit.
-KB
Old 12-24-2012, 06:47 PM   #3
Thanks for the word of wisdom. I'm glad to knwo that the Sylvania trims are good quality. I'm familiar with the Juno cans, co I was most concerned about the quality of the trim and the compatibility with a shallow can.
Also, I appreciate your suggestion about the spacing of the cans. I'll follow the 16" rule for spacing as that is my joist spacing. I'm still curious about a recommendation for spacing though. Is there a consensus of a good range for spacing to get good lighting in a bedroom, bathroom and closet?
-Kiel
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
Wiring a Shed light & internal power DJDesq Electrical 4 08-12-2012 09:12 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
