Best Flxible Drill Bit Setup To Go Up/down Walls For Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 05:28 PM   #1
Best flxible drill bit setup to go up/down walls for wiring?
I asked this in the tool section, but I didn't get any response. I'm hoping in here I might get some suggestions. I am starting to put some new outlets into my 1951 bungalow style home. I am shooting from the basement and only am going about 12" up from the floor with the outlets. It is going to be far easier to drill down through the outlet wall hole, I'm just not sure what the best bit/extension setup is going to be.
Grayguy is offline   Reply With Quote
Old 02-20-2013, 05:35 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Greenlee/D'versibit is the standard.
http://www.amazon.com/Greenlee-DBITK.../dp/B000FBEUVY
I must say, drilling up from the basement/crawl will still be MUCH easier.
The Following 5 Users Say Thank You to Speedy Petey For This Useful Post:
electures (02-20-2013), frenchelectrican (02-21-2013), jbfan (02-20-2013), NJMarine (02-21-2013), PaliBob (02-21-2013)
Old 02-20-2013, 05:58 PM   #3
The hole would be at like a 30-45 Degree angle coming through the floor tho?
Old 02-20-2013, 06:56 PM   #4
And?
Just plan the path of the hole well.
I use a spade bit with a long extension to get the least angle.
Old 02-20-2013, 09:09 PM   #5
Licensed electrician
Rewards Points: 1,028
I use a short stubby bit and a right angle drill. Straight shot into the stud cavity.
Old 02-21-2013, 08:08 AM   #6
Rewards Points: 3,130
This is the way to go. But a right angle drill isn't useful for much else. So if you're a DIYer, I suggest buying a right angle adapter and putting in on a regular drill. They're only about $20 at the big box stores.
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 06:02 PM
Basement Walls - Which Paint?Drylok? HandyFrank Building & Construction 3 10-17-2010 01:07 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
