Bending 35 Yr Old Al 4/0 SE - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2012, 01:47 AM   #1
Rewards Points: 160
bending 35 yr old Al 4/0 SE
I just installed a Reliance manual transfer switch between meter and main panel. Had to bend the old SE to fit it to the lugs in the Reliance. Pain in the ass. It wouldn't bend and then even once bent it would just spring back to its original shape. Had to bend it almost 180o to get it to keep a 90o bend. The new SE 4/0 Al was a pleasure by comparison.
Anybody else had this experience? Anyone know if it's due to changes in the metal over the 35 years since the house was built? Or are we using friendlier alloys these days?
All done, passed inspection. Just curious. Thanks.
philS is offline   Reply With Quote
Old 09-02-2012, 04:22 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,902
Like many metals, aluminum's hardness and springiness varies depending on the metal's temper. Temper is a function of the microstructure of the metal - how large the continuous crystals of metal are and what their shape and orientation are. Newly processed aluminum wire is annealed, so it's in the softest state. It hardens by bending (or any other plastic deformation), but also hardens naturally over time. This is a slower version of the same thermal-treatment hardening process used to make high strength aluminum parts. After 35 years, aluminum wire will have hardened substantially by natural precipitation hardening. This makes it much springier than new wire. There also may be differences in the manufacturing and metallurgical properties of wire from 35 years ago that made it harder to handle.
mpoulton is offline   Reply With Quote
Old 09-02-2012, 10:49 AM   #3
Rewards Points: 160
Yup, thanks, that's what I figured. Be interesting to know though, how much of the effect is due to changes in crystal structure of the metal vs. changes in the alloy composition. I did some Googling but didn;t fid anything useful/relevant.
I am sure I broke the wire bending radius rule on this one rrolleston Electrical 38 03-15-2012 01:29 PM
Bending Pex Through Floor Earnie Plumbing 4 01-12-2012 07:51 AM
Bending Attic Ladder Spring Arm hxs0004 General DIY Discussions 2 10-23-2011 06:05 PM
Steam bending 3/4" pine?? Master Brian Carpentry 12 11-02-2010 04:53 PM
I keep bending blades in recip saw acerunner Tools 10 08-22-2010 12:35 PM
