Bending 2" Rigid Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-05-2012, 10:21 AM   #16
Originally Posted by wewantutopia View Post
Future proofing. We plan on a PV array in the future. Also, possible sub panel to the garage for electric vehicle charging (in the future). Or who knows what the future will bring with the ever increasing electronic world.
If I'm doing it, I'm going to do it in a manner that requires no rework in my lifetime.
Inspector requires the rigid, I'm electing to use the 3/0 (not required by the inspector but a suggestion).
Using 3/0 is NOT going to future proof anything. It won't make any difference with a PV system nor will it allow any "increase for the electronic world". It's a waste of money.
As for the pipe, are you sure that you are required to use Rigid Metallic Conduit? I would talk to someone else in your building department first and ask for your local amendments on paper.
Trane is offline   Reply With Quote
Old 10-05-2012, 09:15 PM   #17
Rewards Points: 175
Doesn't 3/0 over 2/0 allow you to actually pull 200 amps?
Also, there is absolutely NO pvc used for overhead anywhere around here. No SER either. Everything is in rigid.
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 10-05-2012, 09:48 PM   #18
Resi EC
Rewards Points: 252
Originally Posted by electures View Post
The benders used by muffler shops use a tighter radius and won't comply the NEC.
You'll need to point me to the article, I can't seem to find it.
Gac66610 is offline   Reply With Quote
Old 10-05-2012, 09:53 PM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
You really hope you don't pull 200 amps on a consistant basis.
Your electric bill will be through the roof.
jbfan is online now   Reply With Quote
Old 10-05-2012, 10:02 PM   #20
Rewards Points: 175
Of course not, but like I said earlier in the thread we don't know what the future brings. Who knows how much electric vehicle charging on ultra fast chargers will draw for example.
Will anyone else comment on advantage of 3/0 over 2/0?
Old 10-05-2012, 11:29 PM   #21
Master Electrician
There's nothing in the codebook that says "muffler pipe benders bend too tight" its common knowledge for tradespeople that the bend radius on the shoe is too small.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
electures (10-12-2012)
Old 10-06-2012, 05:48 AM   #22
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is 0 (zero) advantage to pulling 3/0's. In fact, 3 3/0's fit just fine in an 1 1/2" conduit.
Old 10-11-2012, 09:30 PM   #23
Rewards Points: 175
Thanks everyone for all the replies.
The only reason I was persistent about the 3/0 wire is that the inspector said that "2/0 is code and just fine but builders around here usually use 3/0..."
I figured there had to be a reason since it costs extra $.
Old 10-12-2012, 06:55 AM   #24
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Thanks Andrew
I should have phrased my response different. A muffler shop bender would be fine as long as the radius meets NEC requirements. Additionally, welding is not an acceptable means of connecting RMC.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Rigid conduit installation help needed socalsteve72 Electrical 35 03-20-2012 11:36 PM
Build A Frame with Rigid Conduit ddaulton General DIY Discussions 3 02-18-2012 12:04 AM
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
