Below Grade Wire Splices - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 11:39 PM   #1
Should wire splices in a round underground box such as one might find for a sprinkler valve or drain pipe clean out be made with common wire nuts? My electrician says it is OK (pool wiring) but I think the wire connections should be water tight. Plastic conduits come up from the ground below into the box. Wires come out of the conduits and are joined with regular twist on wire nuts. The top of the box is flush with the surface of the ground. The splices are below ground level.
InspectorJon is offline   Reply With Quote
Old 07-23-2012, 11:40 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No good... Im also concerned on what circuits you are actually splicing since this is a pool.
Old 07-23-2012, 11:46 PM   #3
Thanks for the the quick response. That is just what I thought.
Old 07-23-2012, 11:48 PM   #4
E2 Electrician
If he is splicing pool lights he has more issues to contend with.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (07-23-2012)
Old 07-23-2012, 11:51 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
My thoughts as well.
Old 07-24-2012, 12:09 AM   #6
"So I Re-Wired It"
MisterZ's Avatar
I think hes only questioning the wires that are already nutted together.
There is no mention of adding additional devices, but the word "splicing" is what makes the statement suspicious.
MisterZ is offline   Reply With Quote
Old 07-24-2012, 12:16 AM   #7
E2 Electrician
My concern is WHAT he is splicing...
Old 07-24-2012, 12:23 AM   #8
"So I Re-Wired It"
MisterZ's Avatar
Yes i understand. Im suggesting this is an existing install hes worried about upon inspection.
Could be wrong tho. Either way, looks like he needs another electrician
Always difficult to diagnose from such limited info. We'll prolly never hear from him again. Lol
Old 07-24-2012, 12:25 AM   #9
E2 Electrician
I agree.
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 10:08 PM
which grade wire to use for grounding subpanel amakarevic Electrical 10 07-09-2011 04:51 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
