Belling 335 Cooker - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 04:17 PM   #1
hubdean
Question
belling 335 cooker
Hello
can anyone tell me how install the belling 335 electric cooker
its the wire from the cooker thats the problem. 6mm cable far to big,
any advise
picture is back of cooker connection point but what cable 6mm far to big could it be 4mm or less ??
thank you
hubdean is offline   Reply With Quote
Old 04-24-2009, 04:58 PM   #2
hubdean
Answer
found the answer
if you undue the screws the 6mm cable slips underneath,if you look closely you will see where the bridging bars are the cable slots either above or below them,this is a simple enough procedure
Old 04-25-2009, 11:10 AM   #3
Rewards Points: 128
Is there not a wiring diagram on the "cooker" somewhere? Look for it on the plate that covers the terminal block (your picture). On the back of the cooker? Or the manufacturer can tell you.
6mm is a large wire, looking at my ruler. How do you know you need this size? What is the current requirement for this cooker?
Old 04-25-2009, 12:00 PM   #4
hubdean
Earth Live Neutral
Earth Live Neutral are clearley marked
the problem was there is no clearley marked space for the cable to fit.
but i got the answer from another site.
i rang help line no use at all.
no instructions came with the cooker.????
just tells you to attach the wires to the right screws Earth, Live, Neutral
as i have never seen a fitting like this i was confussed
but all ok now working fine
thanks for your help
wiring cooker &hob smiderr700 Electrical 2 01-18-2009 04:14 PM
Electric Cooker Tofu Electrical 1 01-08-2008 05:44 PM
Cooker Replacement - Advice chewymix Electrical 2 09-01-2006 07:02 PM
