Behavior Of Non-contact Voltage Detector - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2011, 02:15 PM   #1
Behavior of non-contact voltage detector
I just got a Fluke 1AC-A II non-contact voltage detector.
It seems to work correctly when I test receptacles.
My question is about testing light switches (plastic cover not removed).
These switches are all simple on-off light switches, no 3-way, 4-way or dimmers.
Some switches only give me a positive voltage indication when ON. Others give a postive when ON or OFF.
Why would that be?
Thanks.
bw777 is offline   Reply With Quote
Old 02-16-2011, 04:15 PM   #2
Rewards Points: 6,652
Depends on the magnectic field caused by the Electron flow in the circuit.
Old 02-16-2011, 05:46 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
Might depend on where that circuit is fed from, or the position of the wires inside. If one of the always on wires is near the plate then you are probably picking that up.
Old 02-16-2011, 06:48 PM   #4
Because there is a constant hot always attached to one side of a single pole switch and its a crapshoot as to if that tester is going to pick up the magnetic field through the wall plate.
Never trust that tester by the way. Never.
Mr. Shed is offline   Reply With Quote
Old 02-16-2011, 07:33 PM   #5
Wire Chewer
Rewards Points: 68
I learned that the hard way.
It's funny how fast anything you are holding ends up on the ground when you touch a live wire.
Old 02-17-2011, 09:22 AM   #6
I removed the plastic cover plate, and then the detector was able to detect the voltage. All the connections are back-stabbed, and the wires were all pushed behind the switches, so maybe the wires were too far away with the cover plate on.
non contact voltage testers. 24vac-240vac?? viper Electrical 1 12-21-2010 08:37 PM
voltage on earth wire Spikeyboy Electrical 13 10-15-2010 12:03 PM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 11:39 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
Low voltage box question WShawn Electrical 7 08-19-2008 07:22 AM
