Old 03-31-2008, 01:54 PM   #1
Beginner Question - Residental Switch
Hello, thanks for taking a look.
I'm replacing out an overhead pull-chain light for a recessed light controlled by a switch. The light is powered through a the middle of a circuit connection with the power supply at the load. The power circuit is 12/2.
I have a few questions:
It is okay if I use 14/2 to run the power to the switch, even though the circuit is using 12/2?
Currently, there isn't enough length on the current circuit lines to run to the new light. It is safe to splice additional 12/2 wiring to each end to extend the circuit before connecting them together and then to the light?
Thanks in advance!
willedon is offline   Reply With Quote
Old 03-31-2008, 02:43 PM   #2
When is fishing season?
CowboyAndy's Avatar
Thanks in advance!
You can only use 14/2 if the breaker for the circuit is max 15amps.
you can only make splices in approved junction boxes that remain accessable. You can't just wirenut on a longer peice of wire in the ceiling.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-31-2008, 03:11 PM   #3
thanks for the reply - the breaker is 15 amps, but the power line that runs from it is 12/2. is that a bad thing?
also, do the junction boxes need to be mounted to anything?
Old 03-31-2008, 03:28 PM   #4
1. Just use 12 wire. It will make a number of things better.
2. J boxes MUST be secure and accessible. Homeowners never make their junctions properly and I will be back to troubleshoot it someday. Be kind to me.
220/221 is offline   Reply With Quote
Old 03-31-2008, 05:25 PM   #5
Custom Cabinet Maker
220/221; do we tell him how to run it and change colors?
skymaster is offline   Reply With Quote
Old 03-31-2008, 06:36 PM   #6
I try to limit the info to, questions asked and smart assed remarks.
Old 03-31-2008, 09:12 PM   #7
I thought smart assed remarks were my job ROFLMFAO. Remember I am from NJ and there is no redeeming qualities for us
total air tool beginner question (real e-z) amakarevic Building & Construction 4 12-30-2007 09:56 PM
Switch question gelert Electrical 1 12-22-2007 09:06 PM
3-Way Switch Wiring Question bhpizza Electrical 4 08-07-2007 06:51 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Electrical Switch Question Boatnuts Remodeling 2 03-30-2007 06:56 PM
