-   -   Beginner Question - Residental Switch (http://www.diychatroom.com/f18/beginner-question-residental-switch-19310/)
willedon 03-31-2008 12:54 PM
Hello, thanks for taking a look.
I'm replacing out an overhead pull-chain light for a recessed light controlled by a switch. The light is powered through a the middle of a circuit connection with the power supply at the load. The power circuit is 12/2.
I have a few questions:
It is okay if I use 14/2 to run the power to the switch, even though the circuit is using 12/2?
Currently, there isn't enough length on the current circuit lines to run to the new light. It is safe to splice additional 12/2 wiring to each end to extend the circuit before connecting them together and then to the light?
Thanks in advance!
CowboyAndy 03-31-2008 01:43 PM
Thanks in advance!
You can only use 14/2 if the breaker for the circuit is max 15amps.
you can only make splices in approved junction boxes that remain accessable. You can't just wirenut on a longer peice of wire in the ceiling.
willedon 03-31-2008 02:11 PM
thanks for the reply - the breaker is 15 amps, but the power line that runs from it is 12/2. is that a bad thing?
also, do the junction boxes need to be mounted to anything?
220/221 03-31-2008 02:28 PM
1. Just use 12 wire. It will make a number of things better.
2. J boxes MUST be secure and accessible. Homeowners never make their junctions properly and I will be back to troubleshoot it someday. Be kind to me.:thumbsup:
skymaster 03-31-2008 04:25 PM
220/221; do we tell him how to run it and change colors?
220/221 03-31-2008 05:36 PM
I try to limit the info to, questions asked and smart assed remarks.:whistling2:
skymaster 03-31-2008 08:12 PM
I thought smart assed remarks were my job ROFLMFAO. Remember I am from NJ and there is no redeeming qualities for us:laughing:
