Beginner Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 02:59 PM   #1
beginner question
ok so this is a very basic question, I'm new to doing electric....I have opened up a stud wall and I want to install a 2 switch box between studs on some horizontal blocking. what do you do in this case...I can't find any "new work" boxes with nails going horizontal instead of vertical. i think it would be foolish to use an "old work" box since i have the wall open up anyway. do they make boxes which nail in horizontally? i haven't been able to find them at HD/Lowes...
Thanks!
Greg
c00rdb is offline   Reply With Quote
Old 08-16-2010, 03:02 PM   #2
Civil Engineer
Rewards Points: 4,526
If you have a plastic box, you can screw horizontally through the box into the blocking. If you are using a metal box, you can do the same thing, provided you insert the screw through an existing hole in the back of the box, or drill your own hole. Or you can attach the box to a stud if one is close by.
DRIcore question trailblazer1229 Flooring 0 02-24-2010 10:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 01:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 09:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 05:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
