Bedroom Lights Dim Briefly - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 01:17 PM   #1
Hello,
I am in the process of giving my kitchen a quick face lift. Since my house was built in 59 it had the garbage disposal, one receptacle, dishwasher and Fridge all on one circuit (12/2 wire, 20 amp breaker).
Every time that I turned on the garbage disposal the kitchen lights would dim.
So here is my problem. I ran two independent circuits. One for the Fridge and one for the Microwave. Now my bedroom lights briefly dim every time the fridge turns on. I didn't notice this before when the fridge was on the old circuit with the other appliances. The bedroom light is not on that circuit so I'm a little confused.
Now, I did verify that all of the connections were nice and tight.
Any advise would be greatly appreciated.
Thank you
victor07 is offline   Reply With Quote
Old 12-05-2010, 01:51 PM   #2
Rewards Points: 6,652
Get a electrician in to check for a Loose Neutral at the Panel, also what amperage is your panel, and brand? May also have the local utility check at the meter for poor connections on their end, along with the transformer. Do all rooms in the house exhibit the same problems.
Old 12-05-2010, 02:03 PM   #3
Electrical Contractor
kbsparky's Avatar
Since you rewired the fridge on its own circuit, I'd wager a guess that the new circuit is on the same incoming line as your bedroom lighting.
If you were to swap one of those circuits to the other incoming leg in your panel, the dimming issue might go away without any other action ...
-KB
Old 12-05-2010, 02:25 PM   #4
I never looked at that part, since maybe I have figured to keep things simple in my house by having stuff on separate circuits. My fridge though is on the same circuit as the wall outlets for the dining and the Kitchen, so if that outlet goes bad, I know which Junction box to go tear into.
Old 12-05-2010, 02:41 PM   #5
I have basic electrical skills since I had to take a few courses back when I was in school. I will check all of the Neutrals once again. The Sub Panel is a Cutler Hammer, I'm not sure on the amperage. How can I check. The other lights in the house do not Dim like my bedroom. It only dims for a couple of seconds. Thanks for the help.
Old 12-05-2010, 02:45 PM   #6
Great Idea, let me try that.
Thank you
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 08:52 AM
Bedroom Recessed Lights gregt848 Electrical 11 03-08-2010 04:07 PM
Arc Fault Break Tripping when any light switch turned on elab1 Electrical 60 11-20-2009 01:24 PM
Bedroom lights dim w/microwave Leah Frances Electrical 27 01-21-2009 10:49 PM
How many recessed lights in small bedroom? cdcamaro9534 Electrical 1 01-08-2009 09:57 PM
