Bedroom Gfi - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 02:11 PM   #1
bedroom gfi
I am in the process of selling my house and the inspector said I need to protect the bedrooms weather it be a gfci breaker, afci breaker, or a gfi in each bedroom at the begining of the circuit.
I installed a gfci breaker and when I go to the bedroom with my plug tester and try to trip it, it does nothing.
I then put the regular breaker back in and put a gfi plug in the bedroom and with the plug tester tried to trip and it doesnt trip. is this because there is no ground wire? only a hot and neut in the box.
What can I do to fix this?
paul_arc is offline   Reply With Quote
Old 07-11-2009, 02:37 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Tell the inspector to provide a code referance. If the house was up to code when it was built, then you should not have to update to current codes.
A bedroom does not have to be protected by a gfci in any case, and afci's are only required if you're area adopted the nec to require them.
As far as not having a ground wire, does this mean you only have 2 wire outlets?
A gfci does not require a ground wire to work, but a tester needs a ground wire to trip a gfci.
If you have replace the 2 wire receptacles, then the inspector may be right, but only a gfci, not an afci.
jbfan is online now   Reply With Quote
Old 07-11-2009, 03:10 PM   #3
Yeah there are 3 wire repeptacles in there. when I hit the test button on the breaker it trips but not when I do it with the plug tester. what makes it trip? just the hot and neut touching?
Old 07-11-2009, 03:29 PM   #4
Bigplanz's Avatar
Rewards Points: 990
While code doesn't require you to retrofit an existing circuit that was compliant with the NEC when it was installed, sometimes insurance companies/mortgage companies will require upgrades before they will write an insurance policy/approve a mortgage. I know of at least two instances where panels had to be replaced (old 1970's era split buss panels) before a house could be approved for sale by the mortgage company/insurance policy.
Split Buss panels are perfectly legal if they were installed before (I think) 1984, but they are not code compliant now.
Bigplanz is offline   Reply With Quote
Old 07-11-2009, 04:04 PM   #5
No, GFCI monitors the neutral and compares it to the hot. A ground fault is when the hot goes to ground, thus an imbalance between the two and interruption occurs.
G17GUY is offline   Reply With Quote
Old 07-11-2009, 06:04 PM   #6
By Inspector do you mean a home inspector for a buyer ?
You are not required to bring items up to code that met code when it was built
One exception is smoke detectors & Carbon monoxide detectors
Here those are required
As of NEC 2008 being accepted new bedrooms being built are required to be protected with an AFCI circuit. Right now that means breaker as there isn't an AFCI outlet
Bedroom door with step down Fleener Building & Construction 4 06-10-2009 07:01 AM
Bedroom lights dim w/microwave Leah Frances Electrical 27 01-21-2009 10:49 PM
Painting my bedroom r3dmonk3y Painting 3 12-30-2008 11:58 AM
Beautiful Bedroom Renovation! EdinDesign Project Showcase 11 10-03-2008 01:40 PM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
