Because I Can Pick Your Brain.... 3 Lights, 2 Switches - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2007, 04:20 PM   #1
Rewards Points: 264
Because i can pick your brain.... 3 lights, 2 switches
Originally I was going to run 3 lights on 2 switches down a long closet which has 2 entry doors as such:
A_________________ B________________ C
_________1_________________ 2
where switch one will operate lights A & B, and switch 2 operates lights B & C. Can I make that work? I'm thinking that running all of the lights on a 3-way to both switches (all lights operate on either switch) would be easier.
moneymgmt is offline   Reply With Quote
Old 12-17-2007, 05:14 PM   #2
would work with relays, but a 3-way would be easier
tom25 is offline   Reply With Quote
Old 12-17-2007, 07:40 PM   #3
Union Electrician
goose134's Avatar
agreed. three ways would be easier.
goose134 is offline   Reply With Quote
Old 12-17-2007, 07:45 PM   #4
Electrician philosopher
Yea, but think how cool it would be to have contactors in your closet.
Andy in ATL is offline   Reply With Quote
Old 12-18-2007, 04:25 PM   #5
joed's Avatar
Rewards Points: 13,742
this is sort of an old test question. Here is the answer for you.
http://www.electrical-contractor.net...e/1#Post148756
Old 12-18-2007, 04:35 PM   #6
If your center fixture was a 2, 60 watt lamp style you could simply split it in two as both socket would have individual leads.
220/221 is offline   Reply With Quote
Old 12-18-2007, 05:12 PM   #7
Rewards Points: 1,548
Here is a way you can do it using double pole (not 4-way) switches.
(attached diagram)
The red spots are wire nuts. The red lines represent the poles of the switches.
Old 12-19-2007, 08:10 AM   #8
I love MSPaint CAD drawings.
perpetual98 is offline   Reply With Quote
3 switches 1 light. need 2 lights 2 switches. Im desprete s richards Electrical 6 07-19-2008 03:18 PM
Porch lights with timer or photocell? ciera Electrical 4 10-29-2007 07:35 AM
Hall lights don't work. jagrunner2602 Electrical 13 05-02-2007 11:08 PM
lighting automation christy123 Electrical 10 03-07-2007 04:18 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
