Beachfront Cottage On Stilts - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 08:50 PM   #1
I can't find this anywhere. If it is a repeat, I apologise. I have a cottage on the beach. It is on stilts and the underside is completely exposed to the elements. I am currently upgrading the electrical from the 1954 wiring to something a bit safer. How do I properly route wiring underneath the cottage? Does it need conduits? Is normal Romex good enough? Is the metal sheathed wire what I need? Please help the idiot!
LineJockey is offline   Reply With Quote
Old 05-17-2011, 09:22 PM   #2
Rewards Points: 95
Can't say I know NEC on this, but newer houses in NC's Outer Banks where we rent usually have all wiring run inside walls, or in plastic conduit if run outside. Metal corrodes in sea-spray air. Trouble I have seen is some electricians run plastic conduit where it can be smashed by a car parked under house, car door, boat tie-down, or whatever, leaving exposed wires.
Perry401 is offline   Reply With Quote
Old 05-17-2011, 11:05 PM   #3
Scared Electrician
Saturday Cowboy's Avatar
Romex can not be run outside in any way even if it is conduit. You will need to use wet location wiring methods. Conduit would be my recommendation, However I think u might be able to use UF
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
SD515 (05-18-2011)
Firming up cottage foundation patadams Building & Construction 2 03-23-2011 10:00 AM
1920 Lakeside cottage on jacks- Foundation TROUBLE VelvetParis Building & Construction 15 03-21-2011 09:30 AM
Clay under cottage. Water will not drain. MOLD! Brandon19 Building & Construction 4 11-09-2010 06:35 PM
cottage insulation Cottagers Building & Construction 1 05-02-2010 01:48 PM
Playhouse on stilts TED2235 Building & Construction 0 05-22-2009 10:56 AM
