Old 08-13-2012, 01:48 PM   #1
Battery storage
Hello all,
I recently bought a 12v battery from Amazon to use to power LED lights for a display case I built for my wife.
Battery:
http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
Lights:
My question is:
Can I store this battery in a box of sorts? I wanted to hide it from plain view and was thinking about either building a wooden box or buying a box that I could store this in. I'm asking because I remember reading about needing to allow the battery vapors to escape. Not sure if this is a real thing or not but I figured I would ask some experts.
Thanks!
computerjunkie is offline   Reply With Quote
Old 08-13-2012, 01:54 PM   #2
Battery storage
Sure, its done all the time in alarm systems. Better to used a non combustible case like metal if possible. How are you charging the battery? That seems more important. If you use too crude of a charger the battery might out gas and over heat..
curiousB is offline   Reply With Quote
Old 08-13-2012, 02:01 PM   #3
Battery storage
I haven't really thought about that too much. I was going to buy a 12v charger and call it a day. Are there certain considerations for the charger?
Old 08-13-2012, 09:12 PM   #4
zpm
yeah, right
Battery storage
That's an SLA (sealed lead acid) battery typically used in a UPS.
It doesn't create explosive gas (hydrogen IIRC) like automotive batteries do.
Maybe get an old UPS, preferably a UPS that uses an equivalent battery, and use it to charge the battery.
The simple solution would be to get a 120VAC-12VDC transformer/power brick and run the lights directly, but you must have a reason not to do that.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-14-2012, 10:04 AM   #5
Battery storage
The display case spins on a Lazy Susan Bearing so a direct wire to the wall outlet wouldn't have worked as it would have prevented the showcase from spinning.
Old 08-14-2012, 05:58 PM   #6
Battery storage
Are you going to charge the battery in situ or remove it to charge it? The battery can produce gas and burst if the charging circuit malfunctions. Since that can only happen in a charging situation there is no need for any kind of battery case while using the display. If you charge a battery that small in an area, you don't have to worry about any sort of case. If you want a case, I would go with some kind of plastic rather than metal or wood.
ionized is offline   Reply With Quote
Old 08-15-2012, 12:56 PM   #7
Battery storage
It would be nice to have it so I could charge it without taking out the battery. A retractable cord of some sort comes to mind but I don't think I have the expertise to make that happen (and my wife is anxious for me to be done with this project).
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 06:40 PM
attic storage storageseeker Building & Construction 2 01-29-2009 09:02 AM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 07:58 PM
