Bathrooom/vent/light/night Light Swith - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2009, 09:39 PM   #1
bathrooom/vent/light/night light swith
I need to replace switch but I can not find one like it.
the switch has blue/red going to vent.yellow to light/which is connected to white wire coming into box.black wire coming into box is connected to the black from the switch can some explain how this works. is the white wire hot as the black wire suggest a switch I can use to work here.
thanks vin
vbafico is offline   Reply With Quote
Old 03-14-2009, 10:17 PM   #2
Electrical Contractor
kbsparky's Avatar
Triple switch?
Old 03-15-2009, 06:58 AM   #3
Triple switch available at big box stores and places that sell vent fans. Same isle as the fans.
Old 03-15-2009, 08:27 AM   #4
electrician
They're called "Despard Switches"
Silk is offline   Reply With Quote
Old 03-15-2009, 10:33 PM   #5
If this is what it sounds like, you have 2 switches, 1 for vent and 1 for the light. You can use a "despard" vent light switch or use a "duggle" switch in its place. I have drawn a pic for you and this is what I understand, if not, sorry.
You may have this situation:
Sounds like you have a 14-3 from the fixture to your switch. The neutral is made to the V/L in the j-box. The hot is carried down to the switch connecting to the switch black. The whit and red are commonly a switch leg back to the VL.
A duggle switch has one side with 2 screws connected to each other, this side is the hot. The other side has 2 screws not connected together, these are the switch legs which you would connect the white to one screw and the red to the other.
Hope this helps.
bathrooom/vent/light/night light swith-untitled.jpg
patriot1 is offline   Reply With Quote
Old 03-15-2009, 10:43 PM   #6
Forgot... if you need a night light, pick you up a plug in light with a photocell on it..
Old 03-16-2009, 02:57 PM   #7
bath romm vent/fan/light/n-lite
thanks to all that replyed to my ? I ended up useing the 3 switch
thanks agian vbafico
Old 03-16-2009, 03:00 PM   #8
bath room vent/fan/light/n-lite
thanks to all that replyed to my ? I ended up using the triple switch
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 08:28 AM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
