Old 01-18-2013, 03:54 PM   #1
braves22's Avatar
Question
Bathroom Wiring Question - Tapping Existing Electrical?
I am looking to add a recessed light over the shower....before asked, yet it is wet rated w/ the shower kit.....
I have 2 wall switch outlets currently....one to a set of lights over the vanity and the other to the bath fan....
My question is this.....Instead of blowing out part of my drywall between the ceiling and the wall where the outlet is, would it be possible for me to just tap directly into the exhaust fan on the ceiling that is less than 6' from where I am putting the recessed lighting?
braves22 is offline   Reply With Quote
Old 01-18-2013, 03:58 PM   #2
eastcoastsparky's Avatar
Do you want the fan and light on at same time
Sent from my iPhone using DIY Forum
eastcoastsparky is offline   Reply With Quote
Old 01-18-2013, 04:04 PM   #3
braves22's Avatar
Yes, the recessed light can would only be used when the fan is also on during showers.
Old 01-18-2013, 04:07 PM   #4
Then go ahead make sure you have a watertight trim and use the properly gauged wire
Old 01-18-2013, 04:09 PM   #5
braves22's Avatar
Cool....thanks!
Old 01-18-2013, 04:22 PM   #6
braves22's Avatar
One more ?
Do I need to make any extra connections or pigtail anything or should I just be ok going directly Recessed Wiring > Romex 12/2 > Exhaust fan connecting directly to wiring coming from the outlet source
Old 01-18-2013, 04:44 PM   #7
Electrical Contractor
You will find that the junction box of the fan will be small and will not take another cable.
You might have to add a j box in the attic and feed both from there.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 01-18-2013, 04:49 PM   #8
braves22's Avatar
...And if I cant get into the attic?
Old 01-18-2013, 04:52 PM   #9
Are you going to remove the fan to get your wiring from the light?
Old 01-18-2013, 04:55 PM   #10
braves22's Avatar
Well, I will have to remove the fan anyway to see where the wiring is hooked up and draw myself a plan on fishing the Romex I hook to the recessed lighting from there to where the box is for the fan....
So most likely yes....
What I am guessing next is you're going to say to just replace the jbox for the fan?
IF thats the case, what should I be looking for when I go to buy supplies later on....
Old 01-18-2013, 05:02 PM   #11
The j box on the fan is built in and can not be removed.
Most older fans I have seen and installed can not be done from the floor, but must be done in the attic space.
Old 01-18-2013, 05:06 PM   #12
braves22's Avatar
The house was built in 2003....so old I would doubt....
But I am pretty well certain I can't get there so I guess I will have to somehow find another way.
Old 01-18-2013, 05:08 PM   #13
braves22's Avatar
I guess my next question is, can I even get to the jbox from below ceiling if I can't pull the fan at least partially out w/o major ceiling repair?
Rerouting Bathroom Wiring roasted Electrical 36 05-13-2012 10:58 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 12:26 PM
Bathroom Exhaust Fan / Heat Lamp wiring question MCrom Electrical 2 04-26-2010 09:30 PM
Bathroom wiring ATShome1 Electrical 6 02-26-2010 10:30 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 09:03 AM
