Bathroom Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2011, 07:45 AM   #1
bathroom wiring question
I'm in Ohio. I have a dedicated 20 amp circuit for the bath with 12/2 running to a light, fan and gfci recepticle.
Can I run the power to the gfci workbox and pigtail it to a line running to the switch workbox? My intention being the recepticle is gfci protected but the lights and fan are not. I am unsure if you can split the line in the gfci box.
toobhed is offline   Reply With Quote
Old 08-19-2011, 08:01 AM   #2
Code05's Avatar
Rewards Points: 1,104
You can split off the line side to lights and fan. Most do not require GFCI protection.
Code05 is offline   Reply With Quote
Old 08-19-2011, 10:22 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
If the fan is directly over a tub or shower, there's a good chance it needs to be GFCI protected. Check the instructions.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Code05 (08-19-2011)
Old 08-19-2011, 11:30 AM   #4
Code05's Avatar
That is why I said most. Usually I just install a light/fan combo in the center of the room.
Old 08-20-2011, 05:29 PM   #5
There is no shower, I should have stated that. Thanks for being thorough.
I hope I can get an additional question answered; there is only one outlet in this small bathroom. Is there a requirement as to the distance the outlet can/should be from the sink?
Old 08-20-2011, 05:41 PM   #6
Code05's Avatar
Yes.
210.52(D) Bathrooms. In dwelling units, at least one receptacle
outlet shall be installed in bathrooms within 900 mm (3 ft)
of the outside edge of each basin
. The receptacle outlet
shall be located on a wall or partition that is adjacent to the
basin or basin countertop, located on the countertop, or
installed on the side or face of the basin cabinet not more
than 300 mm (12 in.) below the countertop. Receptacle
outlet assemblies listed for the application shall be permitted
to be installed in the countertop.
Old 08-20-2011, 06:02 PM   #7
Great, thanks! Looks like I'm on track.
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Attic wiring question everyman Electrical 4 07-07-2009 10:47 AM
Question on insulating a bathroom JoshinWV Remodeling 2 12-17-2008 01:22 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 07:25 PM
