Bathroom Wiring Help - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 06:59 PM   #1
Rewards Points: 24
Looking for some help on how to complete the following:
I have wire from panel ran to GFI outlet, from there it goes to a ligth and then down to a single pole switch. I want to add 2 more lights to that switch. When I finished the bathroom I ran an extra wire into the box in case i needed it down the road, it is capped off at the switch and ran into my storage area which is where I want to add the new ligths. The extra wire is not tied to anything right now. What is the best way to complete this?
Hope this makes sense
Roger0205 is offline   Reply With Quote
Old 02-22-2013, 08:22 PM   #2
joed's Avatar
Rewards Points: 12,904
Run a new cable to the light existing fixture and connect into the two wires that are connected to the current fixture. Unless you ran a three + ground cable to the light switch from the fixture you do not have a neutral and can not connect your new light to the cable you ran previously.
Old 02-22-2013, 08:32 PM   #3
Rewards Points: 24
Thanks, was afraid that was the case that I should have ran a 3+. I can't get to the existing light as it's in a drywall ceiling without a bigger project than I want.
Bathroom Exhaust Fan Wiring djberry55 Electrical 3 11-05-2012 12:02 AM
Bathroom Vent Fan wiring help fabster Electrical 5 10-05-2012 12:27 PM
New basement bathroom wiring plan aoeah2003 Electrical 4 07-17-2012 09:12 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
