Bathroom Wiring Diagram - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 03:14 PM   #1
Just call me Andrew
Rewards Points: 1,020
Bathroom wiring diagram
Here's a diagram for what I plan to do in my bathroom. I'm running two new circuits:
15A - lighting, fan, floor heat
20A - GFCI outlet near sink
Anything you would add or change? Is it ok to have switches near the shower like that?
I know I'll need to GFCI-protect the shower lights. Maybe I'm better off GFCI-protecting the whole circuit? If I do that, I know I can use a breaker. Can I instead put a blank-front GFCI outlet in the basement in an accessible j-box and feed the lighting circuit off that? I assume yes, right?
What can I expect from an electrical inspector? Do they just come once or at different stages of the project?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-15-2010, 03:25 PM   #2
Just call me Andrew
I just talked to the electrical inspector I'll be using, and he said the floor heat requires a dedicated circuit, regardless of how much draw it has. I can't understand the reasoning behind that, but I guess I'm running an extra circuit to that bathroom. I suppose I could tap into the receptacle circuit for the lighting and fan, but I like the idea of a dedicated 20A outlet. I also plan to use this lighting circuit on my upstairs bathroom when I renovate it, so that idea is out the window if I put the outlet on it too.
Andrew
Old 04-15-2010, 04:20 PM   #3
Licensed electrician
Rewards Points: 1,236
The NEC does not require the shower lights to be GFI protected, unless called for by the manufacturer. I have never seen any that did, just exhaust fans or fan/light combos over a shower or tub.
Old 04-15-2010, 04:41 PM   #4
Just call me Andrew
Good to know, thanks. I will check the manufacturer instructions, but I am guessing you are correct.
Andrew
Old 04-15-2010, 05:29 PM   #5
Master Electrician
Rewards Points: 3,746
I would suggest being careful with the floor heat TS. The ones I'm familiar with require a deep 4 square j-box with a mud ring. IMO it likely will not fit a multi-gang box with a lot of other cables.
brric is online now   Reply With Quote
Old 04-15-2010, 05:41 PM   #6
joed's Avatar
Rewards Points: 11,976
In Canada those switches would not pass code. They need to be 1m from shower or .5m minimum and GFCI. No way they could be right beside like that.
Old 04-15-2010, 07:39 PM   #7
Just call me Andrew
I forgot to mention that the TS will be above the switchbox. Didn't have a good way to mark that on the diagram. Thanks.
I actually asked the inspector...he said as long as it isn't IN the shower, I am fine. I don't like them being that close, but I don't really have another option...
Andrew
Old 04-15-2010, 08:28 PM   #8
Be sure to use a shower trim if you are using can lights. I would not put the lights on GFI because A) its not required B) if the GFI throws, it will leave you in the dark.
voltech is offline   Reply With Quote
Old 04-15-2010, 08:31 PM   #9
The last in floor heat I installed called for a conduit sleeve from the box to the floor. You may want to locate the Tstat off to the side or below the switch box. A deep box is a definite plus for the Tstat.
Old 04-15-2010, 08:34 PM   #10
Just call me Andrew
I don't think this one calls for the conduit, but I will check. Good advice, thanks. Maybe I'll just put the tstat near the sink instead.
Andrew
Old 04-15-2010, 08:37 PM   #11
Master Electrician
If it has a temperature probe and leads that will be installed after the drywall then some type of wireway will probably be needed.
Old 04-15-2010, 11:06 PM   #12
Just call me Andrew
It has a low-voltage temp probe (I am installing an extra as a backup) that is fished through the wall cavity, behind the drywall. I don't think it runs in a raceway.
Andrew
Old 04-16-2010, 07:39 AM   #13
Just call me Andrew
You guys were right, the manual does call for conduit down to the bottom plate of the wall for the sensor and power line and a 4" square box with a mud ring. I will take that into consideration when thinking of where to place the tstat. Thanks.
Andrew
Existing wiring (with diagram sketch) - is it ok to leave alone or should I rewire Snav Electrical 13 04-05-2010 12:32 PM
Pot lights wiring diagram Eaglenest Electrical 5 03-29-2010 01:09 PM
Basement wiring diagram review majesticjess Electrical 18 03-04-2010 02:05 PM
Wiring Diagram for a Transformer XR72 Electrical 7 08-12-2009 09:20 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
