Bathroom Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 06:58 AM   #1
Rewards Points: 91
bathroom wiring
i am planning the wiring of a new full bathroom that includes a double vanity (6') and a shower with a light-fan above it. i know i need a dedicated 20 amp feed to a gfci outlet but i was curious if i could use 1 line for all lights, fan and receptacle? or is only the rec on this run and all else is off the lighting or rect circuits.
the layout is actually 3 rooms total, from the bedroom the door into the bathroom leads to the vanity room, the vanity room has a door on each side wall to the right is a 5'x5' closet and to the left is the toilet and tub.
gwilkrrs is offline   Reply With Quote
Old 11-28-2012, 07:27 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
One circuit can feed everything in the bathroom but can not leave the room.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
gwilkrrs (11-28-2012)
Old 11-28-2012, 07:32 AM   #3
Rewards Points: 91
so since i cannot leave the room- do you think even though the bathroom is actually 3 rooms in side the main entry door it is still tecnically 1 room with 3 seperate rooms inside?
Old 11-28-2012, 07:34 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
The fan/light above the tub will need to be GFI protected. That isn't a NEC requirement, but it will be in the fan's manual.
Old 11-28-2012, 08:34 AM   #5
Rewards Points: 672
That would probably be a question for the inspector that is inspecting your permits.
B
Beepster is offline   Reply With Quote
Bathroom Exhaust Fan Wiring djberry55 Electrical 3 11-05-2012 12:02 AM
Bathroom Vent Fan wiring help fabster Electrical 5 10-05-2012 12:27 PM
New basement bathroom wiring plan aoeah2003 Electrical 4 07-17-2012 09:12 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
