Bathroom/wet Bar Dual 20/20 - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 05:01 PM   #31
Rewards Points: 16
by the way I'm only 10 feet from my Panel
jiarchibald is offline   Reply With Quote
Old 02-10-2013, 05:03 PM   #32
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by jiarchibald View Post
I don't think I'll need any 12-3 between any thing being wired on the 20 amp.
for the bath, I was thinking of running 12-2 to a 20amp GFCI receptacle. then to the light switch (using pigtails for continuous flow). then to the fan switch (single) to the fan.
For the wet bar Run 12-2 to the 2-20 amp receptacles below counter With Pig tails, to the 2 20-amp GFCI recept. above counter on either side of sink
whatcha all think?
No need for a 20 amp gfci just use a 15 amp one. Just remember if you supply the bathroom with 20 amp circuit for both lights, fan and the gfci receptacle you can't extend it outside the bathroom by nec code.
Everything else looks fine to me be sure to get a electrical box that is large enough to accomodate the gfci as they are a bit more cumbersome than regular receptacles.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-10-2013, 05:04 PM   #33
eastcoastsparky's Avatar
Rewards Points: 150
Sorry about that. It sates right on the breaker that it is a HACR type 2 pole unit j969.
Thats why I referred to it as that
Call it a mini so we dont all get confused
eastcoastsparky is offline   Reply With Quote
Old 02-10-2013, 05:11 PM   #34
Rewards Points: 16
It's my understanding that I wouldn't be running anything outside of the bath with the use of the "mini." One circuit for the bath and one for the wet bar coming from one "mini."
By the way Thanks to everyone who has replied. This is my first home and first time doing anything electrical like this. I can't afford an professional to come in. and the wife is on my a** about getting the basement done HAHA.
Old 02-10-2013, 05:13 PM   #35
UAW SKILLED TRADES
Stubbie's Avatar
Sorry I keep forgetting that some manufacturers call a tandem breaker two pole even though it connects to one bus stab. I think that is very confusing. A two pole or double pole circuit breaker is like this .... and connects to 2 bus stabs on opposite hot legs to provide for 240 volts or a mwbc.
Stubbie
Old 02-10-2013, 05:16 PM   #36
UAW SKILLED TRADES
Stubbie's Avatar
We've all been there believe me ....
Stubbie
Old 02-10-2013, 05:16 PM   #37
Rewards Points: 16
Copy that!
old dual pane vs modern dual pane DIYGST Windows and Doors 2 12-05-2012 12:14 PM
Dual Stage Furnace grod777 HVAC 34 11-05-2011 11:28 AM
NM cable and Dual fuel range edge130 Electrical 0 11-02-2011 04:48 PM
Dual Cap 35/25MDF 440VAC JJboy HVAC 20 10-10-2011 10:12 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
